Now in 993 land ...
aigel's Avatar
Best tickle charger for odyssey 925
So, I am taking the plunge on a new battery for the 993. I wanted something lighter and went with the 925 Odyssey. What is everyone using to keep this topped off for longer periods of rest?
Odyssey sells their brand charger, but it is not a sole purpose maintainer, rather a combo charger which has only clamps - no lead that can be hard-wired to the battery for easy trickle charge connect / disconnect.
Thanks!
G
81 SC (sold)
Old 03-10-2014, 11:05 PM
T77911S's Avatar
i prefer the "tickle me elmo" tickle charger
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-11-2014, 03:43 AM
Air Cooled
Craig_D's Avatar
LOL!
I have the Odyssey 925 and I use this Battery Tender Jr. I had a spare for one of my motorcycles, and started using it before the winter. It works great and kept the battery topped off even when it was in the 20s F in my garage.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-11-2014, 06:50 AM
Now in 993 land ...
aigel's Avatar
I guess it is tickle charger?
So, that's what I find. Some people say the Battery Tender Jr. is a good match for the oddyssey, others say that the world is going to come undone unless you use a higher voltage charger that's specially made for the mat battery.
I'd like to hear a few more opinions before I am charging away ...
G
81 SC (sold)
Old 03-11-2014, 09:59 AM
Danimal16's Avatar
Thanks!
G
YEARs ago, my first Odyssey I maintained on a conventional trickle charger. The batter lasted two years and took the poooop due to over heating. I went out and got the type of battery charger that is specified for a "DRY CELL". I just replaced that battery. It was twelve years old. Do your research on dry cells, the charging and maintaining cycle is not the same as a AGM or a standard lead acid battery.
Dan
Old 03-11-2014, 01:52 PM
Danimal16's Avatar
Odyssey batteries - ACI Chargers
Why not one of these? They can be permanently installed.
I use a OMAX-25A-1B.
Odyssey Ultimizer Battery Chargers
Dan
Old 03-11-2014, 01:57 PM
Now in 993 land ...
aigel's Avatar
Yeah, that looks nice, albeit a bit pricey. How long have you run your battery on one of these? Odyssey?
I would love to buy this but there is no information if these come with fix installation leads or at least a connector that allows to use leads. Can you tell me?
This would definitely the best option. Of course I could change out the charging cable with a fixed lead one as well. Maybe I should just go that route. Then there is no question if I used the right charger ...
I really want this battery setup to last. The 993 is very finicky for getting the emissions codes to set. It is not a good idea to cut power to the ECU unless you are at least 12 months from smog, otherwise the codes may never set and you find yourself at the referee station instead of the smog place down the block ... not the end of the world, but a hassle.
G
81 SC (sold)
Old 03-11-2014, 02:49 PM
I think you'll get more anecdotal than objective opinions, especially on a short thread, thus far.
Try this list to whittle down the top 5 candidates based on your personal "best" criteria:
https://www.google.com/search?q=recommended+battery+trickle+charger&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-USfficial&client=firefox-a&channel=sb#channel=sb&q=review+recommended+battery+trickle+charger&rls=org.mozilla:en-USfficial
Sherwood
Old 03-11-2014, 03:23 PM
Originally Posted by Craig_D View Post
LOL!
I've had the same combination for the last 12 years, couldn't be happier with both.
Old 03-11-2014, 03:30 PM
nineball's Avatar
i have been using battery tender jr models on all my agm batteries for years and never had a problem. one on the 911, one on the bike, one on the mower, two for the jetskis, etc etc etc.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-11-2014, 04:47 PM
G
Okay. Not sure this is the very best one, but I got this recently after my $10 HF battery maintainer bit the dust after 8 years:
021-0123 Battery Tender Junior 12V Battery Charger
..... and it comes with two sets of connection harnesses to the battery; clip on (color-coded + and –) and eyelet terminals for permanent installation to your electrical system.
The very best??? Hmm. Dunno.
Sherwood
Old 03-11-2014, 06:12 PM
Now in 993 land ...
aigel's Avatar
Final setup:
Rennline mount
Odyssey 925T
Battery Tender Jr. - low power consuming unit - CA approved
Pigtail fixed installation - came with the Battery Tender (like that these came with a fuse on the short end of the positive cable)
My reasoning behind buying the battery tender was low power consumption and no moving parts. Reading up on the Odyssey chargers I found reference of a fan that is constantly on. I also could not find information on what cables the Odyssey comes with. At some point you just have to not send your money to a company that can't write up a list of items that are included with the product.
The battery tender may be a little small, but it isn't that I don't drive the car at all. It just has happened that I get in it and it has been 2+ weeks, especially if there is a longer rain spell in winter.
Thanks,
G
81 SC (sold)
Old 03-24-2014, 01:17 AM
Now in 993 land ...
aigel's Avatar
One note on the Rennline mount top strap. It runs pretty close to the battery terminals. You can see that I made an insulator to make sure in an accident things don't short out against the mount. I think the mount is poorly designed in this respect. I should have sent it back and made my own. If I only had the tools and time!
G
81 SC (sold)
Old 03-24-2014, 01:19 AM
