larger batteries can over-stress the alternator when the battery has a very low state of charge, e.g. especially the '82/'83 911SC alternator. |
Anyone know the alternative group size for a battery that utilizes the other threaded hole?
2003 996 Carrera gone but not forgotten '88Carrera '96 993 '89 951 |
My last interstate lasted over seven years. I just replaced with one just like it . Why would I buy anything else?
Well before I can replace, I need to take the old one out. What a nightmare. I have the toolkit that came with my car. It had a long allen wrench that I was able to use to loosen the front bracket.
- do I remove this allen set screw completely? - any idea on how to loosen the ground cable nut? I believe it is 12 mm but can't get a wrench on it to confirm. And if i could, I couldn't move the wrench. HELP is appreciated on how the hell to loosen this bolt so I can remove the cable clamp from the battery post. Thanks
Mark 1988 Black on Black coupe |
Fleabit peanut monkey
I have not connected the vent tube yet. However, I drive like a little girl for the most part. This spring I will install it. Gotta drill a hole, I believe. Thanks for the info.
1981 911SC Targa |
Yes, very tight quarters.
If you don't have sockets, get a good 3/8 set, even the better Harbor freight ones, and see if that can get a bite on the nut(s).
1981 911SC Targa Last edited by Bob Kontak; 03-16-2014 at 04:11 PM.. |
I was able to remove the bracket, and I can budge the battery a smidgen. I'll try and get enough room to get a socket on there. Anyone know what size? Looks like a 12mm. At this point I can get anything on the nut or the square head of the bolt.
Here is what I'm up against:
13 MM. Saying this because they are mostly 10mm and 13mm. On all cars, pretty much.
Get a skinny set of metric wrenches. Skinny meaning wall thickness on the box part of the wrench. The big fat gear wrenches from Harbor Freight have too much thickness (probably) to allow the wrench to slide over the nut. Check at your local auto parts store. I am thinking $30+ for a decent set. They will set you free. Edit: Square head is meant to hold the bolt in place while you loosen the nut. It's all good. Just a little learning curve and a few $$ spent to get a few tools.
1981 911SC Targa Last edited by Bob Kontak; 03-16-2014 at 05:16 PM.. |
Ova Day
Usually a 1/2" wrench works on battery terminal nuts. Move it a teeny tiny bit, flip the wrench, move it another teeny tiny bit, rinse and repeat.
Re: using only metal hold downs and trays; the original clamp was metal but only held the battery by a ridge at the bottom of the battery case. A metal clamp over the top of the battery would certainly be stronger. I don't think there was anywhere near enough room to do that with the original humongo battery. Like the OP said, it is really shoe-horned in there. There is not really enough room to install a proper vent drain tube with the Interstate battery. Re: Drain tubes There are drain holes below that have rubber grommets. A tube could be routed through one of them.
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 |
I have a funny side wrench 13mm to get to that nut...the solution is to remove the 13mm head nut ground from the stud fitting on the inside fender and pull the battery with the ground cable still attached. Clean the ground stud on the fender and the nest of grounds that bolt there from other equipment too, while your there.
If the battery ground cable is old enough to vote..replace it with a new one from our host. |
Just did the same last week. I went with a Sears Diehard advanced gold group 48. It's an AGM which means no leaking. Way easier to maneuver into the space and the mount works with a factory hole. I wound up taking out the front condenser fan to clean up the area due to a PO using a cheap battery and NOT connecting the drain. Seriously?
One note if you haven't done this before, use a box wrench and wrap the handle with friction tape. 1. it won't slip on you and most importantly, 2. you won't ground the positive terminal to the body when you're fussing with the nut. Didn't happen to me, but I've witnessed it. |
Ova Day
My standard 13 mm Craftsman combination wrench works just fine and I remove the cable a couple times a month. The box end only covers half the flats but that is more than enough.
Be sure to remove the negative cable first.
Rick 88 Cab |
Now in 993 land ...
G |
Just installed an Interstate MTP-49/H8 in my 3.2 - was pretty tight getting that sucker in. All is good and it fired right up. PO did not have a vent line attached. I'll have to get one, but having some troubling finding one. Any sources that you all know of?
It didn't come with a vent tube. |
Now in 993 land ...
The batteries should come with a vent line that goes on the bank of openings in the top of the battery. If not, there should be a standard round hole that you can push your existing nipple into. If you do not have a vent line, a trip to the auto parts store should yield a hose and a nipple that fits into your existing lines. You can even just make this from scratch and find a grommet to the outside.
4 yrs old this month (Battery and Spark Plugs questions) ![]() HTH, G |
Ova Day
Do you have any evidence of this?
Rick 88 Cab |
