"Also, I borrowed from your idea SD Swede, thanks. It's a bit off. The second will be better."
1st stab at it already looks fabulous...nice job Dave!
Pete Andersson Pinstriped Early 911 Club |
a.k.a. G-man
It has arrived!.!
I have an awesome knob!! ![]() ![]() Now please someone tell me how to remove the old one from my car.... ![]() (I don't want to use the sawzall... That's not the kind of short shifter I want....)
Сидеть, ложь, Переворачиваться |
911SC Tinkerer
1: Use the open end of a wrench and hit up using a mallet at the base. If your VERY lucky it will come off. If that doesn't work, and it probably won't due to age, you can try again with heat. I used a heat gun and mine still did not budge. Failing all else you can try method two: CAREFULLY use a dremel to cut into the plastic at the base. You need to go extra slow here as you can mar the metal handle underneath. Both methods will result in the destruction of your old shiftknob. If you want to keep it for "originality", I recommend you find a used handle with out a shiftknob attached and use that one. - Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
The reason I don't run one of my own shift knobs....
![]() I have sentimental value in my 911 and there are very few bits I let go, short of disposable parts. I am on the waiting list via a friend, for another stock 915 shifter for my 911, so I can install one of my knobs. I don't want to damage the original knob. SD Swede: Thanks! #2 is being glued up.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
I'm also interested in one for a Wevo shifter, parts catalog doesn't specify if for a Wevo
or not, would like black anodize as well Thanks |
WEVO is possible. PM for pelican part #. Thanks!
Do you offer them in a dark wood/finish like the DZug knobs?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Technically, yes. We'd have to work via PM a bit, since it would be more of a custom order thru Pelican, but it's not a problem.
I believe you ordered one of the Wevo knobs via Pelican today... The knob was dropped off at TRE today. Dave EDIT: One heading to Wevo headquarters and one I believe to 930 ZZZ.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD Last edited by slodave; 10-15-2014 at 11:51 PM.. |
Shift knobs for the 1st and 2nd gen Wevo shifter has now been added to the PP catalog. The part numbers were not exactly supposed to go live right now, as I have a limited supply of the bushings, but it is.
I have 8-9 silver (Al) bushings and 1-2 black bushings at the moment. It will be a few weeks at best before I can have more black anodized bushings available. I apologize for this.
Okay, it's been a while since the last update....
I have prototyped two new bushings. One will allow for a leather shift boot to be attached and the other will be for the 964, 93, 996, 997, Boxster..... It will have the ability to have the shift boot attach to it as well. This is being produced for the 924, 944, 968. Realistically, I can make it for just about any model Porsche and other makes. ![]() This will eventually have the added channel as above and fit 964, 93, 996, 997, Boxster..... ![]() I also have a production run of bushings coming in this week and will have plenty of Wevo and Rennshift bushings in both black and silver. P.S.... I actually turned these prototypes on my wood lathe.
OP. I'm looking to buy this for my 964. I'm a total noobie. Can this work? If so, what shifter and which knob can I work with? Are there options for a darker wood knob?
I'm looking at Carbone and their system is too expensive and the only option I can find so far. https://car-bone.pl/shop/porsche-964-993-shifter-kit/ Thanks! |
price is ridiculous
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
I am just not ready to do that as yet.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
a.k.a. G-man
I did it and it stings while you’re doing it.
But I couldn’t wait and find a replacement shifter... Looks good now so the stinging didn’t last long.
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 03-04-2019 at 01:43 PM.. |
Any photos?
Sent from my iPhone using Tapatalk |
917 Style/Inspired Shift Knobs
Also apparently SLODAVE is too slow to respond to customers. I’ve reached out to him via email, on IG and here. I’ll take my business elsewhere.
Sent from my iPhone using Tapatalk Last edited by gejay; 03-10-2019 at 09:04 AM.. |
a.k.a. G-man
You can get his shiftknob from this site.
Pelican sells them. https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_INTACC_pg3.htm#item10
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 03-10-2019 at 05:38 AM.. |
https://instagram.com/misterfitelo?utm_source=ig_profile_share&igshid=tvx41ohynfwm |
I epoxied a threaded bolt inside to fit the WEVO
