TheSt|G's Avatar
While I'm in the door panel, things to do...
I'm looking to swap my stock door panels to the AppBiz RSA versions, and I was just wondering if there were any suggestions for things to do while I'm in the door.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-26-2014, 10:59 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Grease the window lift drive gear and touch a few spots along the sprocket with same.
Not sure of the best grease for this.
Regulator channels, window channels.
Check condition of those white nylon lock units for the linkage rods. Replacing all would not be a crime but if it ain't broke, why fix it. However, I bet the internal door handle units take more stress than the others.
1981 911SC Targa
Old 06-26-2014, 11:12 AM
TheSt|G's Avatar
I'd probably just use my Wurth sunroof track grease, seems like a similar operation.
Any other thoughts? Always a fan of fresh hardware.
Old 06-26-2014, 11:35 AM
Pavement Pounder
X JBM X's Avatar
white lithium grease has always worked for me on these things....
Old 06-26-2014, 11:37 AM
TheSt|G's Avatar
I think Wurth True Glide is lithium based...
Old 06-26-2014, 11:43 AM
Dave Colangelo's Avatar
Stig,
I made some nice RS style panels for really cheap, I would be happy to help you if you wanted to make them your self here is the thread that documents it
http://forums.pelicanparts.com/porsche-911-technical-forum/647055-rs-style-door-pannels-fiberglass-project.html
I also greased the little plastic bits on all the mechanisms and even replaced a few of the cracked ones. Other than that there really is not much in there. I also put some grease on the hand crank window parts.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 06-26-2014, 12:04 PM
Cars and Cappuccino
tdw28210's Avatar
New vapor barriers.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 06-26-2014, 12:29 PM
^^^ correct!!!
Old 06-26-2014, 12:41 PM
TheSt|G's Avatar
New vapor barriers.
Yup, those were on the game plan as well. Probably will check out the regulator while I'm in there, window seems a bit labored.
Old 06-26-2014, 01:38 PM
Brew Master
cabmandone's Avatar
I'd say make sure the weep holes in the bottom of the door are free of any debris.
Could have a broken spring retainer. I had some problems with my power windows (assuming your 85 has power windows) turned out a small spring retainer had fallen off in each door.
Old 06-26-2014, 02:52 PM
TheSt|G's Avatar
Good idea to spot check the weep holes.
By spring retainer, are you talking about that pot metal post that holds the window clock spring in place?
Old 06-26-2014, 05:54 PM
TheSt|G's Avatar
And on that note, which Weltmeister replacement pin is right for '85 electric windows? Or was it a random grab bag of regulators at the factory?
Old 06-26-2014, 06:33 PM
El Duderino
tirwin's Avatar
How are your door stays? Might consider the reinforcement kit.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-26-2014, 07:13 PM
While I'm in there, I always clean the weep holes along with the seam in the bottom where the door bottom and door skin come together. Maybe lightly sand the areas and apply POR-15 there and the bottom inside of the doors. My car is a '69 so rust is always a concern and water can collect in the bottom of the doors & cause rust. The seams between the door bottom & door skin had a tar like material in them which had deteriorated. Could be they did something better for your '85.
Marv Evans
'69 911E
Old 06-26-2014, 09:36 PM
TheSt|G's Avatar
That's a good thought. I have a good bit of 3M butyl tape from all the BMW window regulators I've done over the years and some extra 3M strip caulk from my upcoming Koni strut project.
It's a little hard to tell with the door on the frame, but I think they looked good. Those have been hanging out on my project list for some time. Good idea on just rolling them in.
In terms of the RSA door panels, the AppBiz kit on this site comes covered in vinyl already correct? It's just a matter of cutting out the holes for the window switches and such?
Old 06-27-2014, 03:22 AM
El Duderino
tirwin's Avatar
When I did my RSA panels I just called AppBiz and talked to Bob. There is no need for cutting. You just tell him what you have -- electric window switches, speakers, etc and he will send you the correct setup. He even metal reinforcements for the switch holes so they just snap into place.
Old 06-27-2014, 04:06 AM
TheSt|G's Avatar
I want to do that, but there is a pretty huge price difference between direct and Pelican...
Old 06-27-2014, 04:24 AM
Brew Master
cabmandone's Avatar
I fixed mine with a bolt. I ground the head for clearance and put a double nut on the top for the spring to hold on. Cheap and most people have bolts laying around.
Link: http://forums.pelicanparts.com/porsche-911-technical-forum/807649-my-window-regulator-spring-retainer-slow-power-window-fix.html
Old 06-27-2014, 05:39 AM
TheSt|G's Avatar
So there is no easy way to know which fix pin is the right one for your year?
Old 06-27-2014, 09:38 AM
Brew Master
cabmandone's Avatar
To be honest, it never even crossed my mind to search for one. I figure the repair I did would last for my lifetime and probably the lifetime of the next owner which I hope is my son.
Old 06-27-2014, 10:49 AM
