Door lock issue(oddness?)
Situation is basically this:
I have an ''85 3.2 coupe with the electronic central locking. Both the center switch and internal lock knobs work as designed. The passenger side door handle key slot can both unlock and lock both doors. The driver's side however can only unlock, it is incapable of locking both doors. Thoughts?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Sounds like a failing micro switch on the drivers side. Been there. Do a search on Door micro switch and youŽll find loads of info.
