911 Besitzer
Did my alternator just die?
I was driving along on the freeway, about 70 miles into a 100 mile drive. Suddenly my car started to lose power. Giving gas first produced a surging/stalling feel, then it just slowed. I pulled over, turned it off, took a look. I am not a great mechanic, but belts were tight. I noticed a 'burning' smell different from my usual oil burning smell. Tried the key, fired up, so I got back on the road. A short time later (minutes), same thing. Dead. I called AAA, and wile waiting, I started it back up again, ran for a while, then rougher and rougher until it felt like it was 'pulsing' then died.
AAA showed up with a flatbed. Driver hooked his battery charge box up. Car started right up and I drove it up onto the bed.
He and I both guessed alternator, though I am no expert. Tomorrow I will try to test it per Bentley, but would appreciate any feedback or insights. Car is a 1984 3.2 Carrera Targa.
Thanks for coming to my aid, fellow Pelicans.
Edit: Battery is brand new, no warning lights on.
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 09-12-2014, 08:33 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Did the alternator red light come on prior to the event?
'85 Carrera Targa
PCA/POC
Old 09-12-2014, 08:38 PM
911 Besitzer
No, the light did not come on.
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 09-12-2014, 08:39 PM
DRACO A5OG's Avatar
Okay, tomorrow was work on 911 day anyways :-)
Check the voltage when car is on, it should be reading 13.5-13.8+/- volts, if no,t the alternator is not charging the battery.
AAA, that's good, so they did the print out diagnostic, right and suspected the alternator.
Make sure all connectors are clean and tight, especially ground/s. Recheck voltage while on, if no change then it is time to remove and have the alternator bench tested, DO NOT FORGET TO BRING YOUR PULLEY HALVES or they will not be able to test it properly, especially at a FLAPS. Some alternator shops may have if they work on VWs but most will not. Get two opinions, I found the same FLAPs a city apart had different results
Caveat, if a rebuild is in order, test it before you leave, you do not want to be re-doing the work again. Ask me how I know :-)
'85 Carrera Targa
PCA/POC
Old 09-12-2014, 08:44 PM
Had the same issue, no light came on. Alternator was toast.
Look on Amazon for the best price on a Bosch unit. I saved $50 over eBay and had no core charge
Old 09-12-2014, 08:49 PM
DRACO A5OG's Avatar
Get a Warranty, these suckers are not cheap, not to mention time costs
'85 Carrera Targa
PCA/POC
Old 09-12-2014, 08:51 PM
911 Besitzer
OK Draco thanks for the help. Tomorrow I will test voltage. I will try the Bentley test of comparing voltages with no accessories on, then turning some on to see if there is a difference to determine if it is the regulator.
I got this car to work and learn about it. I'd prefer to not have the lesson start on the side of the highway!
And this was going to be my weekend to attempt the Triangle of Death!
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 09-12-2014, 08:52 PM
DRACO A5OG's Avatar
Ah ha, so it was a 911 day :-)
ah so, the Triangle, if you do a partial drop about 4-6 inches, it will make it a breeze to knock that sucka out. Just note for the breather, you have to bend the engine hanger loop out of te way to access one or two of the nuts. Important when you put the breather hose back, take careful note of the hose connector portion of the breather, there is a indent and the hose clamp can not sit on it or you will have a oil leak. PM me if you ave any questions on this or the alternator test procedures.
Stay well brother, thank goodness for AAA, they saved my but many times :-)
Jim
'85 Carrera Targa
PCA/POC
Old 09-12-2014, 08:59 PM
911 Besitzer
dmg_dirtsquirt: I will look at Amazon and see if I can figure out which one I need, though I may also see if mine is salvageable with a local rebuild.
Draco: You may very well get a PM from me at some point this weekend.
I really appreciate the help my friends!
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 09-12-2014, 09:06 PM
DRACO A5OG's Avatar
Us Targas got to stick together
'85 Carrera Targa
PCA/POC
Old 09-12-2014, 09:15 PM
wwest's Avatar
Solid state component over heating, I vote for ignition control module, alternate choice, rev limiter.
Battery being overcharged..... causes either.
Old 09-12-2014, 09:32 PM
84 is a DME car.
Rick
88 Cab
Old 09-12-2014, 09:53 PM
T77911S's Avatar
the car was able to turn over and start...several times? i would not think alt.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-13-2014, 02:46 AM
muck-raker
kidrock's Avatar
how about the DME relay?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-13-2014, 05:06 PM
scottb's Avatar
I had the identical symptoms in my 84 Targa. The alternator was bad.
There's nothing "magic" about the alternators in these cars. A good foreign alternator rebuilding shop can rebuild it for you. No need to go to any great expense. I think I paid about $85 10 years ago. The alternator is still going strong.
1984 Targa
Old 09-13-2014, 05:24 PM
911 Besitzer
I am pulling the alternator tomorrow, and will get a local Pelican to refer me to a shop to have it checked/fixed.
I suppose I should probably go ahead and get a DME relay 'just in case'.
Thanks again for all the help and advice. I will update this thread as things progress.
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 09-13-2014, 09:37 PM
Does not sound like alternator. Sounds more like a fuel or sensor thing but 3.2's are very electronic so??. As always the only way is to test things in order. You can test voltage at battery with it running, no need to remove from car. Don't change stuff willy nilly.
912's"65 PD ,67 SWT,68x3,76e"
911's"68SWT,71S,73.5,76,82,88"
88 944 turbo,99 m coupe,01 coxster, VW bugs"65,74,72 V8"
68 E type,01 XJ8
US500 mbz
Old 09-13-2014, 11:39 PM
T77911S's Avatar
take the car to advance and have the system checked, they do it for free.
RACE CAR:: sold
Old 09-14-2014, 03:34 AM
scottb's Avatar
It never hurts to have a spare DME relay in the glove box.
1984 Targa
Old 09-14-2014, 07:16 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Surprised the AAA wouldn't measure the battery voltage?
But as others said it doesn't sound like battery/alternator. If you ran down the battery in your first event to the point where the DME gave up (~ 9 Volt) there is no way it recovered to where it could turn over the engine with the starter. You would have gotten nothing, not even dash lights....
If you really smelled something electric burning I'd focus on the DME under the drivers seat. That or the ignition switch might have overheated from a fault and that's what you smelled. To smell a frying alternator takes A LOT in a 911. I'd say its unlikely unless that thing is on fire. Remember the engine fan drives air down the engine guiding any smell right out and away.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-14-2014, 09:31 AM
