Basic suspension refresh
Hi guys,
I have been getting my 84 911 in order over the past 6 months. It has about 120K miles and runs pretty well. I noticed some squeaking when I bounce the car. It's difficult to localize the source of the noise. I looked at my spring plate covers and the plate is very eccentric coming through the cover. The front lcontrol arm bushings look cracked and hard as well.
I thought I would do a street rebuild and replace with ER rubber on the spring plates, front control arms and both f/r sway bar bushings.
Does this sound reasonable.\? I will also tweak the ride height and get an alignment. Any other ideas?
Thanks,
Dave
Old 10-15-2014, 05:45 AM
Undocumented User
McLaren-TAG's Avatar
Yeah, throw in the ball joints and if you haven't already, turbo tie rods.
Old 10-15-2014, 05:54 AM
TheSt|G's Avatar
As long as you are getting an alignment, I would refresh a bit more than that. I'm just under 100k and my refresh is going to also include new ball joints up front, new front and rear struts, and new strut mounts/all associated hardware. The front mounts will also be getting new strip caulk and such.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 10-15-2014, 05:55 AM
Good points guys. I forgot to mention that the PO replaced shocks with new Bilsteins, and installed turbo tie rods.
Thanks,
Dave
Old 10-15-2014, 06:03 AM
TheSt|G's Avatar
Thanks,
Dave
How long ago?
And did he do the ball joints?
Old 10-15-2014, 06:04 AM
If that squeak is bothering you, I'd find that and fix it first. Use two people if necessary. Otherwise you won't be happy.
I had a click / rattle sound that I thought was coming from the rear. Took the help of my wife to find it was coming from the left front, and had to jack the car up to duplicate the noise. Took almost an hour to find it was the camber plate.
Other than that, your list looks good. I replaced all of that on my car. The front control arm bushings were really lopsided and in the worst shape of everything on that list on my car. Good luck, take your time, and enjoy doing it. The car has to be the easiest and most fun to work on of any I've had.
Matt - 84 Carrera
Matt, you are so smart! I have one of those magic ear clip on microphone things. I was unable earlier to localize, but today just for fun I clipped in on my left rear new shock. The sqeak is coming fro something in or on the shock. I would have done the suspension work and still had the noise. Thanks. I don't usually jump to conclusions like that. I think I will still do the suspension work, but now I have to investigate why a 2-year old shock would be noisy.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-15-2014, 06:30 AM
I'll mark that down on my list of times I've been right in my life.
That makes two things on the list now.
Matt - 84 Carrera
Old 10-15-2014, 08:19 AM
TheSt|G's Avatar
You and a stopped clock.
Old 10-15-2014, 08:31 AM
BTW this is a cheapie question. 4 new Bilstein HD shocks 3 years old. The left rear is squeaking. Given the young age of the items, can I just replace the bad one.
Thanks,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-15-2014, 02:50 PM
Well, I'm answering my own question. I purchased one replacement shock, same as the 3 year old one.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-15-2014, 04:30 PM
Charles Freeborn's Avatar
I haven't read all the way through, but here's my .02ç
Do all the brakes - you'll never have easier access to the lines and hoses than when the front end is out. All the soft lines to and from fuel tank, and steering rack re-bulid too.
If you've got the rear apart just go ahead and service the CV's and rear hubs (bearings, etc) and clean out all the grunge in the e-brakes too.
-C
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 10-15-2014, 08:14 PM
Thanks, Charles. I was thinking more basic, than complete. My car rides pretty well. The bushings look pretty tired, and one shock is bad. The brakes have been rebuilt and lines replaced.
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-16-2014, 07:23 AM
