they look awesome!
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 04-12-2015, 04:46 PM
NeedSpace's Avatar
I cannot believe how nice and "modern" the bbs wheels look. Used to only seeing it in the familiar gold, the gray makes them look quite nice.
Old 04-12-2015, 07:43 PM
Wow those look amazing. What are your offsets in the rear?
Old 04-13-2015, 05:55 AM
skinnerd's Avatar
The rear wheels use a 5" outer halve along with a 6" inner halve.
The backspacing is about 5-9/16" (tad over 5.5").
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 04-13-2015, 09:31 AM
Came back just to see these wheels, they look too good.
I need to learn how to build wheels, brand new 3 piece wheels are outrageously priced nowadays.
Old 04-16-2015, 09:31 AM
skinnerd's Avatar
Relatively simple to do....regardless what a wheel manufacturer may tell you.
Always use new O-rings between the wheel halves.
Make sure everything is clean.
Bolt them up, and torque to ~13 ft-lbs.
I then run a bead of silicon sealant around the entire perimeter where the O-ring
is as a backup against air leaks.
Sometimes good 2nd hand wheel halves are available.
If not, new ones are not inexpensive.
I spent $150-200 per halve.
Doug
Old 04-16-2015, 10:43 AM
Nice I appreciate that, I'll do some hunting around and hopefully you see me posting about it soon!
Old 04-16-2015, 04:07 PM
SWISS in cali
Grand-sapin's Avatar
What size are your barrels? inner and outer? thanks!
05 Audi S4 Avant
65 VW Camper bus
03 Audi TT Roadster
04 Cayenne S
98 Audi A4 Avant
Old 05-08-2015, 08:59 AM
Fast Mike's Avatar
Excellent!
Old 05-08-2015, 01:14 PM
who do you guys recommend to polish the chrome 3 pc rims from E50 bbs wheels? does all reed do the rims only? i will reassemble myself.
thanks .
frank
Old 10-20-2018, 12:48 PM
