Coram Deo
Yes, lights are on with the car off (or on).
Yes, cruise is still installed, though I've never used it. The light doesn't decay overnight. When I open the garage door in the morning, they're still on. It's late here now, but I will do the diagnostics in the morning. Thanks!
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
I sent you a PM. Please check it. Thanks |
Gordon,
For the flasher, you would use the dual turnsignal indicator version. The single indicator version is for the 914 '74-'76 years. From your PM, you saide the driver brake light doesn't light. So just the driver side brake light doesn't work? The driver side running light does work? It might be that the button inside the vehicle socket is oxidized or bent backwards. Try cleaning both buttons and GENTLY pull them outward. You can clean them by scratching them with a small screwdriver. Do this with all power off in case you short the button to the side of the case while working on it.
Find Spoke's LED Products: www.spokeworksled.com |
So with the car running and no brakes applied, the 3rd brake light and the normal brake lights are very gently on? This is characteristic of the cruise control sense lead on the brake light wires. No one ever said their lights stay on after the car is turned off though. If you don't use the cruise control and want to test this, try disconnecting the CC ECU and see if the leaking stops.
Coram Deo
Here's the brightness of the third brake light, though the taillights are on so you can't see the two brake lights glowing.
![]() Plus one of the front because it's beautiful.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio Last edited by RDM; 02-18-2018 at 02:50 PM.. Reason: clarity |
Correct-my driver side running light does work, but not the driver brake light-so only the driver brake light does not work. I will try your suggestiont-However my regular bulbs when installed today worked just fine. I will keep you posted |
I've seen it happen where the buttons on the LED boards may not be as bulbous as those on the bulb. This could cause the loss of contact you're seeing.
That glowing of the 3rd brake light is from the cruise control ECU. Good thing you don't use the CC as it wouldn't work now. We solved this issue with the 6ohm 100W pigtail which gets installed in the front trunk by the brake master cylinder. The resistor network (there's two 12 ohm resistors in parallel) gets connected from the brake light wire on the brake master cylinder to ground.
Making progress on the front running lights for my Porsche 356 friend.
This is the first LED board. The LED lens holders are now glued on and some test fitting has been done. The heatsink on the back of the board still leaves a lot of room inside the fixture for the switching converter board. The LEDs burn about 16W and I've measured a temperature rise of about 40C. This is ok as even if the ambient temperature is 40C (104F), the LEDs will be running at a cool 80C. They're rated for junction temperatures up to 150C so shouldn't have any issues there. I will have to make sure the converter can handle the high temps. ![]() ![]() ![]() ![]()
Coram Deo
![]() I wonder what could be special about my car.... Do you have instructions and/or ordering info for the pigtail? Many thanks.
I don't have a schematic for your 911 so I can't help figure out why the cruise isn't turning off. I assume it's the cruise ECU not going dormant that the brakes stay on gently when the key is off. With bulbs you would never see any light although the leakage is still there. If you're not using the cruise and you can find it (I think it's in the cabin on the passenger side under the glove compartment, try disconnecting it and see if the brake still light with the car off.
It seemed like my contacts on my rear driver side had to be pulled out to make contact and connectivity. Issue: I am hyper flashing...in your previous post you mention that I would need a LED compatible EP 36 flasher....Once I get the flasher do I have to many ANY modification to the flasher or can I drop it in and go about my business? You mention in the other post (somewhere in previous to page 38 of this post) that you were going to buy some and modify them...Is this still correct? I am not a electrical guru. Any suggestion on adding a FAQ on your website--with all these questions and answers fielded--you can direct them to your website and refer them to ...See FAQ #44 for your concern, etc, etc...you can literally just copy and paste all from these 38 pages and not reinvent the wheel |
Hyperflashing
Anyone who have these lights installed-can you asssist---I have the LED's installed on 1985-911 but now I am hyperflashing.
Can I just add a compatible LED flasher to stop this or do I have to make modifications to the flasher itself...there seems to be some contradiction on this from the other post. Car is stock, model year 1985-911 Coupe. Thanks |
Formerly known as Syzygy
I just used Spoke's flasher that was LED compatible.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 02-28-2018 at 04:17 PM.. |
The flasher needed is EP26. EP26 is as close to the OEM 911 flasher which is LED-compatible as any on the market. The pins of EP26 are exactly the same as the OEM flasher and plugs right in to the flasher socket. The only shortcoming of EP26 is the C2 pin doesn't connect to anything inside the unit. On some 911 models and all 914 models the C2 pin drives a center connection to the two turnsignal indicators in the tachometer. See the schematic below for the '73 914 which is electrically equivalent to some 911 models. In this diagram the K lead of the flasher is the same as the C2 lead on EP26. Because C2 is open in EP26, I pop the lid of EP26 and connect C2 to ground. I do have the connection that I do on my website under tech articles.
I connect C2 to ground and resell EP26 although you can do this yourself. I have a tech article on my website of the change to make. It's quite simple if you have experience with soldering.
Honestly, I would rather buy a complete ready to plug in EP26 flasher from you than try elementary soldering that I have never done before....let me know how you want to proceed. many thanks. Gordon |
PM sent.
