spoke's Avatar
Install the screws such that each screw is started but not seated. Go around each screw until they seat. Remember they're #2 screws going into plastic and not head studs. Once some resistance is encountered and they look seated, stop.
Then fish the wires through the hole in the reflector and reinstall.
Find Spoke's LED Products:
www.spokeworksled.com
Old 09-28-2019, 08:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #921 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
Originally Posted by spoke View Post
The issue I'm working with is the light distribution of the LED lenses available. Below is the light distribution for Carclo Optic's 10192 lenses when put in front of Cree XP-G high power LEDs that I'm using. These lenses do not have a sharp cutoff like modern headlights have. I've tried to create some shades to cut off the upper range but they did not work and only cut the total intensity.
So I'm sending out 3 sets to some 911 owners for them to evaluate. The LED Fogs work well as DRL and I don't think they're too obnoxious at night. I want to get more opinions before doing general availability. The LED fogs burn about 9W per light and put out 2x the light intensity as the 35W bulbs. Plus the LEDs being used are 5700K color and very compatible with LED headlights.
When you refer to them not being too obnoxious at night, you mean for the drivers, right? Because people aren't running their fog lights with headlights and other traffic on the road...
I don't think having a sharp cut off like headlights for the fogs is completely necessary as they're not used with other oncoming traffic present. Perhaps that tight control of the light direction might reduce their effectiveness. Ok, reduce might not be the right word as they're not all that great to begin with...
Regardless, your five degrees down angle should mitigate the amount of light that seems to be directed further upward.
Kevin
Old 09-28-2019, 09:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #922 (permalink)
4flyboy's Avatar
Clear Marker/Blinker Lenses source
Hey Spoke,
Thanks for the update on the fogs, I'll belly up to the bar and buy some when you perfect those.
In answer to your source question for clear front Marker/Blinker. Our host isn't carrying.
Rennspeed Motorsports (www.Rennspd.Com) originally told me they were out. They found a set of Markers on the shelf for $45 delivered. And they're GREAT quality.
Sierra Madre is back-ordered on markers (December) but has the Clear Blinker lenses ON SALE for $16.41 each!
If these sources get blocked by our host, PM me and I'll hook you guys up
I'm off to order LED's for these clears and a pair of reverse for the 911....
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 09-29-2019, 08:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #923 (permalink)
Just to follow up on the fogs, I've been using mine as DRLs since I got them and they're still going strong. If anyone has specific questions on installation that I can help with, please ask but obviously Spoke knows more than I do.
1986 911 Carrera Coupe
2016 VW Golf R
2008 Toyota Highlander (given to kid)
2021 Kia Telluride
2020 BMW R1250RS
Old 09-30-2019, 06:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #924 (permalink)
Spokeworks LED Fog Light Review
I have lights from Spokeworks all the way around the car and couldn't be happier with them, with these fogs Jerry has outdone himself. Install was a non-issue following the instructions posted here. In the case that someone did run into problems Jerry is a great guy to communicate with and stands behind his products 100%. I plan on using these as DRL's for added visibility or to add some great low surround lights when up in the mountains at night. Excuse the crappy night pics but you'll get the idea of just how bright these are. Drove around with them on for a bit and didn't have anyone flashing their beams at me so I would say the low angle is spot on. Highly recommended
This is fog lights only, no running or headlights
Old 10-03-2019, 08:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #925 (permalink)
Canada Kev's Avatar
Yellow lenses, I presume, and not the actual LEDs?
Kevin
Old 10-03-2019, 08:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #926 (permalink)
@Canada Kev
Correct, this is with the yellow lenses on. The lights themselves are white
Old 10-03-2019, 11:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #927 (permalink)
Finally got around to doing the RS rear turn signal/brake light LED upgrade from Spokeswerks.
All in, install took about 12 minutes start to finish with no issues. Jerry has been excellent to deal with thus far. I think I'm going the distance and ordering all the other LED products he offers for my car.
Note: I had LEDs on the car already. Every exterior bulb was already swapped to another brand LED bulb but they have been breaking and are unreliable. Spokewerks products are the business and are built better than any relationship I've been in to date so I'm not worried about their lifespan. They will outlive me.
Photos of the car they went on:
Quick install pics:
Lit up in daylight:
I'll take better shots tonight with a good camera to emphasize how easy these were to install and how well they light up all the cars behind me.
Old 11-05-2019, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #928 (permalink)
For the led turn signals did you buy amber or red?
Quick install pics:
Lit up in daylight:
Old 11-22-2019, 11:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #929 (permalink)
Fogs
Here is a photo of my recently installed LED fog lights. They are a very close match to the LED headlights I got from Audette.
David Yerkes
1987 911 Targa - GP White
Old 11-22-2019, 11:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #930 (permalink)
spoke's Avatar
Christmas Sale at Spokeworks
5% off all products. For orders over $200, use coupon code SPOKE for additional 5% off.
Merry Christmas
http://www.spokeworksled.com
Old 11-29-2019, 10:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #931 (permalink)
spoke's Avatar
I've added the 911 foglights to the website with introductory price of $125/pair. The final price will be $150/pair.
Old 11-29-2019, 11:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #932 (permalink)
Red, as per suggestion of Jerry.
According to DOT regulation, you can't actually have yellow lights on the rear of your car that light up outside of turn signal or hazard light application. The only way to get the turn signals to light up as "DRLs" in their dim setting was to have the bulbs be red.
Does this make sense? I'm bad at explaining things.
Old 11-29-2019, 12:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #933 (permalink)
spoke's Avatar
The hardware for the foglights now includes a jig to assist with the removal of the bulb holder and shade.
The jig fits around the bulb holder provides a stable platform to tap out the bulb holder.
Old 01-06-2020, 07:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #934 (permalink)
spoke's Avatar
There are 3 nubs holding the bulb socket onto the reflector.
Using a punch or screwdriver, tap on the nubs going around the circle until the socket pops out.
Socket popped out.
Socket is removed.
Old 01-06-2020, 07:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #935 (permalink)
cpg123's Avatar
I received my package with your fog lights this afternoon and immediately started dismantling my headlights. I was wondering what the big round “jig” was in the bag of parts.
I just finished installing the first fog light and will try the jig tomorrow when I attempt the second one.
1987 911 Targa
2017 Macan S
2017 911 Carrera 4S
Old 01-06-2020, 08:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #936 (permalink)
spoke's Avatar
I just posted instructions on my website. I knew you were going to get the lights today and tried earlier to get the instructions online.
Old 01-06-2020, 08:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #937 (permalink)
Cars and Cappuccino
tdw28210's Avatar
Spoke,
Posted a GIF of my brake lights with the flasher module installed on a large Facebook group page 2 days ago. Had a few inquires from friends as to where they the lights could be purchased. Now I am getting ready to post the link form your website now. Wanted you to be aware in case you see a spike in demand.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 01-10-2020, 11:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #938 (permalink)
Originally Posted by tdw28210 View Post
Spoke,
What Facebook page?
Old 01-10-2020, 01:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #939 (permalink)
David's Avatar
Spoke, since this thread is 47 pages long, I might have missed it but have you considered making a taillaight housing designed around your LEDs? It could be much simpler than the original housing so it would be easier to make and lighter.
Old 02-09-2020, 06:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #940 (permalink)
