Another outstanding product by Jerry; thanks for constantly working to keep our cars safe.
'71 914-6 #0372 '17 Macan GTS |
It's been 35 years since the last 911 to use that reflector, yet... The innovation keeps coming. You love to see it.
I deleted the license plate lights on two of my cars. Hmmm, those wires are just sitting there, doing nothing, when they could be operating these "auxiliary running lights." 🤔
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
I wasn't satisfied with the finish of the silver covers so they were reprinted with black PETG. Also did some post print processing by sanding the cover and painting them. Look a lot better.
Since the brake boards were red the pinch clips for the board were also printed in red. ![]()
Find Spoke's LED Products: www.spokeworksled.com |
Coram Deo
And there you go. That's the key to everything, isn't it?
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
I'm looking for a volunteer to test out an e-ballast for cruise control ECU compatibility. The current solution is to provide 6 ohm high power resistance always connected to the brake light wire.
This solution uses 6 ohm low power resistors switched in with a relay. With brake lights on the ballast resistor is not needed and is switched out. The 6 ohm resistance is needed only when the brake lights are off. This point was noted by Engelbert in conversation about turnsignals. I need someone to actually test it out. If you have one of the high power ballasts just swap this one in and see if the CC still operates. Let me know if you're interested. TIA.
Hey Jerry,
Ill be happy to test it out for you. I have your full setup. Thanks, Saadi Sent from my iPhone using Tapatalk |
Thank you. PM sent.
