Spoke,
I would be interested in purchasing a set of taillights that have already been modified to reduce the running light by 33% or more...to give it a more distinct contrast between the tail lights and brake lights. Thanks Gordon Quote:
Runnin on empty
Hi Spoke,
Just pulled the trigger at your website for RS brake, RS signals, side, Fronts amb/wht and relay. These will compliment the LED headlights I just fabbed very nicely. I tried some of the other led replacement bulbs. While they were an improvement over the old filament type I felt that I wanted something more powerful. Really looking forward to installing. Having just gotten my car back on the road I believe your lights will be an added measure of insurance for accident avoidance. And they just look way cool! Thanks
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
Coram Deo
Spoke,
Have you considered making a 3rd high-mounted brake light? Something suitable for coupes and Targas, with a housing that keeps the light out of the cabin, maybe? We're discussing it here: http://forums.pelicanparts.com/porsche-911-technical-forum/1006971-third-brake-light-anyone-made-housing-2.html#post10172029
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Here are some pics from our Sunday drive that bring justice to spoke's kits (since I suck at taking pics myself):
I have 2 sets of 911 brakes for you to try out. One has only 1 resistor and the other set has 2 resistors. The normal board has 3 resistors all of which are in parallel so removing any of the 3 resistors will reduce the running light intensity. Try out both versions and keep the version you like best. It's yours for free for doing this testing for me. Send back the other set when you are finished. Resistors R2, R3, and R4 are in parallel to set the running light current. It can be observed that R3 is missing on one set and R2 and R4 are missing on the other. ![]()
Find Spoke's LED Products: www.spokeworksled.com |
Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Coram Deo
Well, if you are doing lights for a Ferrari, nothing is outside your purview, right?
Jerry-Thanks for doing this, I will keep you posted! Gordon |
The 911 front sidemarker that I make is actually a full fledged turnsignal. I don't know of anyone who has added the extra wire to have the sidemarker LED board flash brightly as a turnsignal. I'd really like to see how the sidemarker doubles as a turnsignal. I offered to RocketWrench and I'll offer to 1 or 2 others that I'll give a free set of sidemarker LED boards if you have a set of front turnsignals and agree to add the extra wire to make the sidemarkers flash brightly with the front turnsignals and comment about it to me or on this thread. Anyone interested? ![]()
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Installed a full set a few weeks ago. Results are great, as expected, though my front right corner isn't working correctly for some reason that I will diagnose soon.
'80 SC Targa Avondale, Chicago, IL |
The socket is held on with one screw allowing access to the 2 wires. Swap the wires and likely the board will light up. Contact me if you have any questions. BTW, nice looking 911.
Aja, thanks! I'll check that.
The turnsignal wire is obviously available in the turnsignal bucket but might be easier to work with in the headlight bucket where all the turnsignal, sidemarker, and headlight wires converge. This would require removing the headlight to gain access to the wires. I could make a Y-pigtail to add the wire to the turnsignal to help this along. Included as well will be a single connector like shown below to be added to the Y-pigtail to connect the board to the turnsignal wire. ![]() Here's a Y-pigtail I made to connect my LED headlights to the running light power for DRL. The Y-pigtail for this work would have a longer wire to be fished out of the headlight bucket and over to the sidemarker. Then the crimp on button connector can be added to get turnsignal power to the boards. If you're still in after seeing what's involved, we'll be good to go. ![]() This picture shows the turnsignal, running light, and headlight wires located behind the headlight. The 2-wires at the bottom go to the sidemarker.
I'll have to pull a headlight out to look at the wiring again to see how to add a pigtail for the turnsignal power to get it to the sidemarker. With the Nor'easter hitting us now it looks like the 930 isn't coming out of the garage any time soon.
Here's a couple more examples of how LEDs aren't as long lasting as we're all told they are.
This first example is a Prius whose left brake LEDs have some sort of power issue. The running lights on this car are off as when the driver released the brakes, there were no lights on the rear of the car so these are only the brake lights. Looks like all the LEDs were lit but were lit very gently. Likely the power source for these is a constant current supply which has some type of issue. I don't think this will pass inspection and I doubt anyone except the dealer would be able to remedy this. ![]() This truck's lights are all having issues staying lit. Only the leftmost LED fixture is all lit up. Looks like there are 10 LEDs in each fixture. Unless these have a smily/frowny face feature, I'd say they're not holding up well to the truck's daily routines. ![]() If you thought that retirement might mean your LED lights will last longer, think again. This blurry picture from The Villages in Florida sees the left LED brake/turnsignal light on this cart with 2 LEDs out.
