Low Class Yuppie
-Cam 1984 Porsche 911 Carrera Coupe "Porsche ownership is like AA. You can be a hedge fund manager or a stock boy at Menard's. Nobody cares. Common ground." -Bob Kontak |
Still here
The manual says to pause for a few seconds before engaging reverse. |
Or just go 2->R.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
If you are using more than 3 fingers to shift, something is wrong. I've got 145k on mine, no rebuilds. Bushings replaced and factory sport shift using Swepco forever.
Always double clutch and match revs on downsifts, it's fun. |
Eva
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Eva
I posted it here as it seemed like an opportune time, but as silly as it may sound, I think it sounds the age of the trans and I wouldn't fix it even if it were broke ![]() Like old race cars whose transmissions whine and crunch gears...I love it!
The OP's 915 is probably typical of most 915s. Dino oil needs to warm up a bit for shifts to become smooth.
It's a trap...
When I got mine, I had to talk nice to it to get into first. I changed the bushings and it got better but still not great. I "freshened" the tran, 1 and 2 dog teeth and sliders and blocks etc. now it goes into first gliding into a stop with no issues. Course it's not running now, but that's a different story.
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
Fleabit peanut monkey
I have heard it does but I have no basis aside from what I have heard/read.
1981 911SC Targa |
Bob, can't imagine why that would be. Length of travel should have no bearing (no pun) on the wear factor for the synchros. I think people want there to be a "tradeoff" for the benefit they get from short shifting.
PS - the video linked below is pretty good, for being from the 1930s. Simplest explanation of synchros I've ever seen. They have another one regarding the rear differential on Hemmings that is also quite good. Tech 101 – How manual transmission gears work | Hemmings Daily
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
I learned from my dad to go into second before engaging first or reserve From first to second, take the shifter to the middle then left again into second, not just strait back from first to second PITA but no grinding |
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
My 915 is from an 86 Carrera, and is installed along with a 3.2L engine in my 74.
Mine shifts fine when warm into and from 1 2, 3 and 4. Sometimes finding 5th when rolling along at 55 or 60 is troublesome, as I cannot seem to find my way over to the 5th/R gate. I have to be careful because quite often I am now in 3rd. We are going to convert back to a stock shifter and away from the aftermarket short shift unit (which my mechanic thinks may be my problem). He has had trouble with it too. If this does not help, we will have to remove it and take it apart.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries! 1974 911 RUF Clone ('85 3.2; '86 915) 1974 914 ('87 3.2L & 915 transaxle) 2005 Boxster (Base car) Guards Red. |
I have the middle one on my 81. Back when it was just over $100 in the 1800's. Myth is probably "justifiable" if you slam the short throw shifter as fast as you can vs. the long throw. I shift like a little girl after the $2,500 nut to rebuild.
1981 911SC Targa |
Schleprock
I think the 915 operation and bad rap has been inflated by many poor repair approaches and abuse.
By poor repair approaches I mean "rebuilds" that ignore blunted dog teeth, replace only the synchro friction band and reuse of the slider sleeves/rings. I think the sleeve/ring part is arguably the most important to replace because it engages the dog teeth AND the synchro friction band. But yet this part seems to be the one most people look at and assume it looks OK visually and they put it back in. Another bad repair approach is so many people hope to fix the shifting with external fixes and fluid change. Sure, shifter bushings and coupler bushings are important. So is a fresh gear oil. But often by the time those items need fixing, the internals of the trans have also suffered. Yet most are only willing to look at the external stuff and the fluid and hope that fixes things. Transmissions are really neglected by a lot of people. People will change engine oil all day long and debate what oil to death. But transmission oil is almost an afterthought to a lot of these same people. Regarding abuse, I think some people believe the 915 is a tainted trans and there's just no chance of it ever shifting good. Reality is a lot of shifting is done really poorly and the trans can only compensate for that so much. A lot of people are notorious for yanking the shifter before the clutch is fully disengaged and the 915 doesn't like that. Over time that bad shifting habit can distort the dog ring by trying to pull its press fit off the gear. Another abusive behavior that a lot of people are completely unaware of is matching RPM on downshifts. Not only does it wear out your clutch when you don't match RPM, but you also put more wear on the synchros. Sure the more modern cone style synchro G50 transmissions are better at managing unmatched RPM, but even they will eventually start crunching. I had an 83K mi. G50 in my '87 that was clunky going into 2nd gear when cold and would crunch 3rd gear during fast shifts when hot. So it had obviously seen a lot of heavy shifting to be crunchy at *only* 83K mi. The reverse crunch is definitely related to the non-synchronized reverse gear assembly. It's not a problem with the trans in terms of it being something amiss. It's due to the lack of synchronization to slow down the straight gears as they're trying to mesh. With the engine running, clutch out and trans in neutral, the shafts inside the trans are all spinning. Push in the clutch and those shafts begin to stop spinning. If you quickly go for reverse while they're still spinning somewhat quickly, you'll get the crunch every time since the reverse slider hub has nothing but bare, albeit rounded-edge, straight teeth on it that are attempting to engage with the same type of teeth on the reversing gear pair. But if you select another gear like 2nd or 4th or whatever other gear before you go for reverse? You're using that other gear's synchros to slow down the spinning shafts and that's what lets you get into reverse without crunching.
Kevin L '86 Carrera "Larry" |
Cars Ruined My Life
Now you guys are making me want to take the transmission out and apart.... :d
^^^Great stuff Kevin
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
gearhead
The reason to pause is because you are waiting for the internals of the gearbox to stop spinning. You should be at a complete stop and clutch pedal to the floor. In neutral with clutch out, the mainshaft will still be spinning the gears.
