Brew Master
cabmandone's Avatar
Tach not working after engine drop an install
I got my engine back in my car and got it fired after replacing head studs but my tach isn't working and it worked before I dropped the engine. I had to miss a wire somewhere. The connector in the tunnel had a broken wire that I repaired. I'm going to go back through my intake runner grounds and make sure all are making contact and I already checked the ground strap from the transmission to chassis.
Any suggestions?
Old 06-18-2015, 09:14 AM
T77911S's Avatar
first suggestion is to state the year.....of the car
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-18-2015, 09:41 AM
Brew Master
cabmandone's Avatar
Sorry, it's an 85. Not sure how much difference that makes when it comes to the tach other than my tach wiring works differently than the early year cars. I guess I figured the 3.2L was a giveaway for 85 or newer. Didn't consider transplants but figured transplants would be using motoronic.
Old 06-18-2015, 10:41 AM
ROW '78 911 Targa
timmy2's Avatar
DME plug, 14 pin plug solidly connected?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-18-2015, 10:49 AM
Check it as timmy2 says. Plug under the seat, near the DME box. Tach wire runs from there up to the back of the tach.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-18-2015, 11:02 AM
Brew Master
cabmandone's Avatar
Have to recheck my connection to the DME. I might not have it squarely connected. I'll let you know if a few minutes.
Thanks for the suggestions.
Just checked, connectors are all tight. Noticed when I fired it to check, when I shut the car down the tach jumped a little. Don't know if that helps or not.
Old 06-18-2015, 11:06 AM
Yes do both, reseat the LARGE DME connection as well as the 14 pin mentioned.
Old 06-18-2015, 11:15 AM
Brew Master
cabmandone's Avatar
No joy. I unplugged the Main harness and plugged back in. I also cleaned all the grounds back at the intake runner. Tach still jumping when I shut the engine off. It seems like I have to be missing something obvious since it worked 3 weeks ago when the engine came out for the head stud replacement.
Old 06-18-2015, 11:36 AM
Brew Master
cabmandone's Avatar
I'm going to check the connection on my speed sensor. If it checks good, I'm going to verify the correct gap again. I think the speed sensor is what tells the ECM how fast the engine is turning.
Old 06-18-2015, 12:23 PM
If speed sensor didn't work properly, AFIK engine would NEVER start or run!
Old 06-18-2015, 01:01 PM
Cabmando
Really interested in this because my '76 2.7L is doing EXACTLY same thing. Tach worked before engine drop, no work after engine install, Tach needle jumps a slight bit when I turn the engine off.....I've hear ground strap betweem tranny and body, I just havent gotten under there. My strap is really frayed.
1976 911S, sleeping for 13 years, back to life in 2013!
Old 06-18-2015, 03:43 PM
Brew Master
cabmandone's Avatar
Originally Posted by gjmascoli View Post
Cabmando
I'm going to get under my car this evening and check that strap. I know I tightened it but I'm going to recheck. I was thinking there was nothing I unplugged that would effect the tach but there has to be some connector that sends signal back to the Motronic for it to process the signal. I'm going to go over the wiring schematics and recheck all my connectors. It has to be something simple.
Old 06-18-2015, 04:15 PM
Think about it for a moment, on earlier cars with CDI ignition, the tach signal is developed IN the CDI unit. Same for DME, as the "CDI" is contained within the DME box. The signal is not driven by any sensor on the engine.
The tach pulses are sent from the DME on DME connector pins #4 and #11. #4 blk/violet wire, #11 blk wire. These wires run direct to the rear off the tach. Pull the DME connecter loose and check their continuity with a multimeter to the rear of the tach.
Old 06-18-2015, 05:36 PM
Brew Master
cabmandone's Avatar
Good suggestion, I'll give it a try if I get time tomorrow. Darn work is going to get in the way of me working on my car!
FWIW I got under the car and checked the ground strap at from the trans to chassis and all was good. I cleaned it and reconnected. Still no tach.
Old 06-18-2015, 07:32 PM
Pin 21 blk/violet wire is the ignition signal to the tach.
Pin 11 blk wire is the fuel injector pulse widths for the CASIS light.
Rick
88 Cab
Old 06-18-2015, 10:26 PM
83 911 Production Cab #10
JJ 911SC's Avatar
As per Bentley 240-12 (Fuel Injection)
Who Will Live... Will See
Old 06-19-2015, 02:53 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Above post ^^^^^^^ is why the Bentley manual scares me; it suggests pin 11 and pin 21 are identical. That is far from true. More likely the authors didn't know which pin does what.
Rick has it right. Pin 21 puts out a pulse for each spark event. This is used by the tachometer to display RPM. Pin 11 carries the fuel pulse length. The duty cycle of the signal is evaluated in the tachometer to decide when to turn on the shift light.
Further, if you mix these wire up when connecting the tachometer you will inevitably destroy your DME. First the car will run lousy and next it will quit altogether with no fuel. The reason for this is that the signal on pin 11 comes directly from the fuel driver. And when you hook that wire up to the tachometer input the pull-up resistor of the tachometer will drive current into the DME and destroy the fuel driver. This is an expensive repair.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-19-2015, 05:35 AM
Sorry for a bit of miss information I gave on pin assignments, but the pic above is not true for all Carrera years!
I was looking at ACTUAL wiring diagrams in the Bentley, 970-30 '88-'89 DME does use
pins 4 and 11 for the tach. I just looked at it and assumed all years of DME were the same.(my bad to assume) Pg 970-26 shows the '84-'85 Carrera diagram, and indeed it uses pins #21 and # 11 to the tach. As the OP has an '85, pins 21 and 11 it is.
Obviously the '84-'87 DMEs are different than the '88-'89, at least for the tach signal.
Didn't know that, or is the Bentley possibly in error?
Old 06-19-2015, 05:36 AM
ischmitz's Avatar
All NA 84 - 89 use the exact same pin-out for the DME. Pin 11 for shift light and pin 21 for RPM. Pin 4 is the starter (to turn on the fuel pump via the DME relay).
The turbo is completely different, it doesn't use a DME.
Ingo
Old 06-19-2015, 05:42 AM
Ingo
Ingo, I agree that the picture used could lead to mis-wiring, however the wiring diagram on 970-26 shows the wire colors #21 blk/violet and #11 blk. The #21 blk/violet is the only one needed the run the tach. The black
wire #11 can be disconnected if you don't require the upshift light (anybody really need it?)
Old 06-19-2015, 05:50 AM
