CHT removal _ hot or cold engine?
New thread on a current issue I am resolving with help of others on this board.
When removing my CHT from my 84 3.2, with 50k and 15 years on it, do I want the engine hot, cold or warm? PB blaster applied twice in cold engine so far. Have not touch the sensor yet. I know the first turn on the sensor is the most important to removal without incident. Thanks, Dave |
Make America Great Again!
I replaced mine with a cold engine. This little bugger was difficult. The grommet was a pain, use soapy water. Cut the wire and use a deep 13mm to remove. Have you made the 14mm special socket to install yet? I got a grinder and a cheap deep 14mm from Sears, and put a groove in it so the wires would slide by.
Make sure you buy the two wire. |
San Diego, CA
Sorry but what's a CHT?
CHT is Cylinder Head Temperature sensor. FWIW, I replaced mine in my 3.6 cold. Used a modified deep socket with a slot in it and penetrating oil.
1990 964 Coupe 1986 Carrera 3.2 Targa |
I did mine cold. Cut the wire, use a good quality socket that fits properly.
I guess it is physically possible to do it on a hot engine but that sounds like a great way to have some new burn scars. I made a tool to install the new one. Just a little grinder work and Dremel work. Look around on the other threads on CHT removal. A picture of the tool is worth a ton of typing. Easy to make the tool.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Here's a pic of a modified socket posted by brujo65:
http://forums.pelicanparts.com/porsche-911-technical-forum/904281-3-2-60-days-sitting-bad-miss-under-load-2.html Are people saying the old one is 13mm? I know the new replacement ones are 14mm
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Did mine cold.
I anticipated problems but it was thankfully easy. If you do remove it warm, I would do the install cold.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Spiderman
13 out, 14 in
As I remember it several years back, it was a 13mm that came out but since I was removing it for replacement, just cut the wires and used a standard socket. To install, I took a deep 14 or again as I remember it, took a decimal deep socket (there is one pretty close to14mm) that was spare not being used in my box and slotted that to install. You only lightly torque it.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Thanks All, came out nicely with PB Blaster and cold engine. Just waiting for the new one in the mail........
Dave |
