Who can restore/repair this fuel line?
I would like to get this fuel line restored back to its original condition (and most likely replace the lines).
Does anyone know of a place that does this?
1987 Porsche 911 Carrera Coupe
Old 03-05-2018, 09:02 AM
old man neri's Avatar
That looks like a stock 3.2 fuel line. There are several options.
1) Order new parts from Porsche
2) Order aftermarket parts from some place like griffiths.
3) Talk to some guy named len and see if he can make you a new set if you send in your old set
4) Find a competent local hydraulic hose shop that can cut off the old hoses and crimp on new ones.
5) Make up your own set using AN fittings and what not.
Old 03-05-2018, 09:09 AM
newb.
eimkeith's Avatar
Those are still available from Porsche
Sent from my iPhone using Tapatalk Pro
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 03-05-2018, 09:20 AM
Len Cummings Porsche service repair Auto Sport Engineering - Stow, MA call or email
Old 03-05-2018, 09:29 AM
G50911's Avatar
len [boxsterGT] here on pelican can fix you up
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 03-05-2018, 09:37 AM
thanks all!
Much appreciated!
Old 03-05-2018, 11:17 AM
Hi
Targa Me's Avatar
I re-did my own fuel line.
I used high pressure fuel injection hose and fuel injection hose clamps.
You can use wire dikes to peel away the crimped collars.
It works great. Now I replace the fuel hoses every 100k miles and it only cost a few buck.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 03-05-2018, 11:41 AM
proporsche's Avatar
Hi..trakrat..most of my stuff on my 911 including oil lines is done by these boys ..
https://ormebrothers.com/
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-05-2018, 11:50 AM
GOM (Grumpy Old Man)
Busta Rib's Avatar
Speaking from experience and replacing all my fuel lines recently (on a 3.6), I recommend going OEM for that spider system of fuel lines. I used a local hose shop (very good, BTW) to fab a couple new single lines for me. Although the quality was great, the fit wasn't OEM and it was a little too tight for my taste.
With the complication of the lines you want replaced, I think you are better off buying from Porsche so you know they will 1) fit and 2) work as expected. There are a lot of attachment points with that part that you don't want to get wrong and end up with expensive fuel lines that don't fit.
Instagram: @3pedalposse
Old 03-05-2018, 06:10 PM
BoxsterGT's Avatar
Porsche Crest
Good day Trackrat -
I am happy to help. Here is a Re-Hose of a customer's original Main Tee AND Crossover I just completed and shipped a few days ago.....
The J-Hose is new, I cannot Re-Hose that.
For more info, please email me. I do NOT respond to pms. Cannot send photos or track messages so its a waste of time for me.
I am retired and do this as a thank-you to the Porsche community for 45+ yrs of pleasure repairing, restoring, driving and owning these wonderful vehicles.
Len at Autosportenginering dot com
PS - Thank you Len T.
Old 03-06-2018, 06:13 AM
I'll chime in as one of many of Len's satisfied customers. He made new soft lines for my SC's Megasquirt setup a few months ago.
'80 SC Targa
Avondale, Chicago, IL
Old 03-06-2018, 09:30 AM
My point has been, the lines from porsche have been on the shelf for nearly 30 years, nearly $500
For antique fuel lines...
Bruce
Old 03-06-2018, 09:59 AM
3rd_gear_Ted's Avatar
Tunnel fuel line design blindness and tunnel vision for OEM fuel lines and components go together.
Reliability engineering in aircraft is mostly based on component age, environment and usage cycles
So much modern stuff to upgrade with from end to end.
Do you sometime admire the results of plastic surgery ???
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-06-2018, 12:15 PM
BoxsterGT's Avatar
Porsche Crest
I have custom Metric fittings for Alum or SS tube through the Tunnel if anyone wants to go that way.
A few well known Pelican members have done this with very satisfactory results.
Please, NO pm's. Inquire at: Len at Autosportengineering dot com
Old 03-06-2018, 12:41 PM
evan9eleven's Avatar
+1
Len is the go-to guy for fuel lines, he made everything I needed about a month or so back. Recommended.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 03-06-2018, 01:20 PM
KTL KTL is offline
Schleprock
KTL's Avatar
When you're replacing/rebuilding these fuel hoses, be sure to take a look at the return line in the engine bay/chassis that has a rubber flex section on it. That one has the same potential as the rest of them for leaking at the crimp joints.
I just found mine ready to leak 3 weeks ago. https://www.youtube.com/watch?v=b5AEbQy4HOQ
I believe fahck is German for "darn it?"
Kevin L
'86 Carrera "Larry"
Old 03-06-2018, 02:12 PM
Yup, I replaced that one as well. Unscrewed it from where it comes out of the tunnel and gave it to the hose shop. They made my up a new one including the hard line portion which was starting to rust.
That being said I am not quite sure how you would replace that one without dropping the engine/tranny. I suppose you could cut the old one out and replace it with a flex line.....doesn't sound like fun though.
Old 03-06-2018, 02:20 PM
Thanks for this... I'll check it out as well.. might as well replace everything I can.
Old 03-06-2018, 02:35 PM
this place also have them:
https://griffiths.com/porsche/engine/porsche-911-fuel-lines/
'76 911 Carrera 3 - '81 911 coupe - '82 911 Targa - '83 911 Cabrio - '83 911 coupe (3.6 engine,964 body kit) - '86 911 coupe (ROW 3.2)
Old 03-06-2018, 03:52 PM
