g50 oil change found something strange on magnet
like the title says,
while doing a tranny oil change there was a small cylindrical pc of metal on the drain plug magnet. anybody know what this is? ![]() the transmission seems to shift fine. notchy when cold but smooth once warm. was rebuilt about 5 yrs ago. it is my brother in law's car so i dont know the extent of the tranny rebuild, nor do i know who did it. i did try the search function but i couldn't find any info. thanks, lorenzo |
Project Addicted
That looks like a shift rod detent. Never taken apart a g50 so don't even know if they have them.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
Ohhh that's an awkward problem. Judging from the size that should be in a shift rod.
It's very easy to misplace during a teardown of the tension plate. Your trans has the potential to get into two gears at once-sorry. If you have access to PET you can look up the drawing. I can't recall offhand which rod it goes into-maybe the 3/4? but it has to be installed during assembly and there is no way to fix it without tearing the trans down. Or put it under your pillow or somewhere and hope you don't find yourself stuck somewhere with corvette people around snickering!
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
Wow. OK, thanks for the info. I don't know what PET is but I assume some sort of exploded parts diagram. Is it a possibility that the rebuilder left it in there by accident and my bro in-law is lucky?? I doubt it. I need to know how serious this can potentially be. He is unfortunately not on good terms with the company that rebuilt his trans. Thanks , Lorenzo |
It's very easy to misplace that during assembly. I put some grease in the hole on the shift rod
to hold it until the rods into position. Assuming the detents are all working which they probably are considering he's been using it without issues the odds of having it engage two gears at once are fairly slim.
![]() i truly appreciate your help. thank you, lorenzo |
gearhead
Agree with Mark. Probably an old assembly error and not an about to self destruct new problem.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Autodidactic user
Yup. Certainly what I saw in my 915. Look at picture number 2. Transmission reassembling 915 transmission Is the G50 the same?
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
One positive aspect, it doesn't look damaged and it won't cause damage now.
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
The PET is the Porsche Factory parts catalog. You can find your car here: Porsche Classic Genuine Parts Catalog - Porsche Cars North America It is a .pdf and you can save it to your computer.
