Tori's Avatar
And she's out. Luckily a friend rang me up and asked what i was doing. LOL So, naturally i invited him over.
(and luckily he was there to help)
I'll start tearing down what i can with it on the floor..... and making a list....
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 01-02-2017, 02:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
And no bumper removal. NICE
Wait, doh, you have access to a pro-shop to use those giant jack stands.
Congrats!
'85 Carrera Targa
PCA/POC
Old 01-02-2017, 02:04 PM
Tori's Avatar
nah, these are just my regular stands.
Lemme know when you're done with that engine yoke.
Old 01-02-2017, 02:07 PM
Nice...you are in for some fun..Did this 2 years ago and I am envious..Miss having a winter project..Look forward to this story...Cheers
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 01-02-2017, 02:46 PM
Still here
pmax's Avatar
Congrats !
Don't forget the obligatory ... dude or in your case dudes in the engine compartment pic
Old 01-02-2017, 04:24 PM
Tori's Avatar
Thanks. Is that really a thing ? Ive heard that twice now. LOL
Couple quick questions...... how do i get the cylinder head temp wire off the sender ? Or do i just remove the sensor ?
What hose went here ?
Also, can this pipe be replaced, my rubber section is cracked. Or do i just need to remake my own ?
Old 01-02-2017, 04:43 PM
Tori's Avatar
Oh, and here ya go
Old 01-02-2017, 04:57 PM
The Dude abides...
bigel's Avatar
Nice work...just spent the last two years doing the same on my '87.
Having just completed the work I can give this advice; everyone should rebuild an engine one time in their life...ONCE!
In all seriousness, I did enjoy the process and will certainly go through the process again, if and when the need should arise.
Enjoy the process and, don't spend too much money on 'while you're in there' type items!
Good luck.
'03 Carrera 4S
Old 01-02-2017, 05:23 PM
Always Be Fixing Cars
HA I think I posted that exact pic in my thread: http://forums.pelicanparts.com/porsche-911-technical-forum/772047-1st-drop-top-end-observations-questions-4.html#post7674773
I ended up using self fusing silicone "rescue tape" per the suggestions on my thread. Its worked for three years...
see also http://forums.pelicanparts.com/porsche-911-technical-forum/428782-repair-vs-replacement-options-part.html
'91 964 C4 - New Daily
'73 Alfa GTV - 90% done 50% to go
'65 912 - Welding in process
Old 01-02-2017, 06:30 PM
Tori's Avatar
ok thanks for the link and repair ideas.
Spent the evening stripping the motor down .... got this far, plus removal of the oil cooler.
Any reason NOT to take the pressure washer to the transmission ? This thing is filthy !
Old 01-02-2017, 10:34 PM
DRACO A5OG's Avatar
You Animal :-D, Love It!
'85 Carrera Targa
PCA/POC
Old 01-02-2017, 10:56 PM
Tori's Avatar
Great, you'll be here for the assembly.
Old 01-02-2017, 11:59 PM
The Dude abides...
bigel's Avatar
If you search the forum you'll see that others have, though I didn't at the time when I was cleaning mine...wished I had as it took me quite a long time with oven cleaner! I guess I wouldn't have had that 'lemon fresh sent' any other way...
'03 Carrera 4S
Old 01-03-2017, 02:57 AM
The Dude abides...
bigel's Avatar
Here's mine...before and after.
'03 Carrera 4S
Old 01-03-2017, 03:09 AM
DRACO A5OG's Avatar
No problems Pressure washing, just mask the TOB Guide Tube, Upper Vent, Reverse Light Switch and Nose In Put shaft seal. Try not to focus on the high pressure stream on the masked areas and DIFF's flanged ends for obvious reasons, then use compressor to blow away excess water.
I am taking mine to the local self car wash.
'85 Carrera Targa
PCA/POC
Old 01-03-2017, 06:06 AM
Tori's Avatar
Not much progress today. Had to go back to work.
I did get a handful of parts run thru the parts washer at work though, and removed the flywheel and rear main seal. I'd have to say it was leaking, at least i hope it was as that would explain some of the oil leaks this pig had. But, with everything leaking from up top it's hard to judge any other leak areas below.
Two fresh questions:
Name this part- Found it laying at top of engine.
Any cool fixes for the deteriorating insulation from this wiring ? It's literally crumbling apart. I figure i'll slit some appropriate vacuum line and recover it. Thoughts ?
Old 01-03-2017, 08:09 PM
DRACO A5OG's Avatar
Vacuum hose is a nice trick, just make sure they Ohm out properly.
As far as the metal thing, hmmm, never saw anything like that on mine or other 3.2s. put a ruler to it so we can tell what it might go to.
'85 Carrera Targa
PCA/POC
Old 01-03-2017, 08:21 PM
Tori's Avatar
Here ya go...
and check out this puddle of oil sitting on top of this valve. There were a few like this. Sheesh !
Old 01-03-2017, 10:49 PM
DRACO A5OG's Avatar
Hmmm, that one is a strange one.
As far as the oil, signs of too much oil in the tank.
on previous post, that blue rim tab goes to the AAV.
'85 Carrera Targa
PCA/POC
Old 01-03-2017, 11:34 PM
Tori's Avatar
AAV ?
Definitely not too much oil in the tank. With as much as it was leaking/burning, it was always about a quart low. And i mean a qt. under the preferred middle mark.
Old 01-03-2017, 11:41 PM
