Oil Level gauge not working-1985 911
I just got back my 85-911 from the shop and my oil level gauge is not working. Drove a few hours and the needle never moved(actually flickered). The light turns off when I start the car, the car just got back from the shop, there is oil in it as I checked yesterday and today I pulled the gauge back to see all wires intact.
Any suggestions? |
See if it came disconnected in the engine bay.
I don't have your motor. I have a 2.7 and mine is a single wire right side and is back by the chain covers.
That Guy
You can see the level switch in the attached picture. Look behind the passenger rear wheel and you will see it on the car, make sure the wires are still attached. Should be two wires; one connected at the center and another on a spade connector of one of the five nuts.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Thanks-will have to check it out in the morning, will let you know. Gordon |
Mine is a 3.0 but when mine flickered as you say, I cleaned off the ground (?) in the rear passenger wheel wheel, added some oil, ( it was a bit low) and all was good.
JUAN '80SC Targa |
Will the tank contact leads be in the vertical as pictured above? good idea on cleaning the grounds when I am there.
My oil sender does not move unless the engine is hot enough to open the front cooler. If the dip stick shows the oil at above the minimum mark and you still get no movement on a hot engine, check the sender.
That picture shows a nice clean tank and connector. If your 85 is like mine, and gets driven it will be crusted with road grime. If the wire is connected, taking out the sender is pretty easy, but you will want to get a new gasket. Use some cleaner, a brush and flush with water to clean up the area first. Undo the nuts and remove the sender. Then you can move the sender up and down and see if the Ohms change. It is all super easy to do.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Mine did the same thing.. found out I was about 6 quarts low!!!!!
1987 Porsche 911 Carrera Coupe |
remove the wire and the needle should show max, ground it and it will show min.
verify the gauge to the dipstick. engine running and hot. I did a thread on cleaning the sending unit but cant find it. my gauge does not "work" until engine is warm.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
I came across this thread the other day as I was searching how to change out the gasket. Should answer your questions on how to remove the sender.
http://forums.pelicanparts.com/porsche-911-technical-forum/958649-changing-oiltank-swimmer-gasket-when-installed.html
Rob 1985 911 Carrera Targa 2016 Boxster Black Edition Last edited by RLJett; 02-21-2018 at 08:25 AM.. Reason: forgot link |
Hi Gordon..most of the time the sender is not sending the correct info is simple.There is a cork gasket and it does go bad-becomes thinner.This way the sending unit gets grounded.
Do as suggested..take the ground wire and with the ignition key on, touch the ground (the tank for example) with it,the needle should go down to zero.If it does you unit is most likely ok. You can lift this side of the car a little and remove the oil level sending unit and replace the cork gasket.That is all.The gasket goes on only one way.So while you are ready to install, put it on the unit it self and then slide it on the tank. Use washers under those little nut.Make it tight but not too much so you do not crack the cork gasket.... Ivan Hi Rob ..thanx i could not find this one;-) Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 02-21-2018 at 08:43 AM.. |
I found a broken very fine wire in the resistance track on my in-tank sender. I was able to resolder it. I used a microscope to see and fix it.
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
Gents,
I removed the sender wire and the gauge showed max, grounded the wire and it went low. I just ran the car for about 7 plus miles --enough to get the engine and temps up to par. Not once did the gauge even move---After getting back home with the engine running, I checked the oil and I found it to have sufficient oil on the dipstick--more on the lower end of the stick, but still not low enough not to have the issue I have. |
Thanks for the info, I will order the cork gasket and associated hardware and see if that does the trick-will keep you posted. Gordon |
So here is dilemma, I already ordered the cork gasket.....should I also order the sender unit....or hold off and see how the cork gasket solves the issue.
Thread Tools | |
Rate This Thread | |
