proporsche's Avatar
well ..everybody does what they want with their engine work and cleaning, i have done most of the cleaning on 50 plus engines just by my self;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-25-2018, 03:36 PM
Somewhere in the Midwest
MotoSook's Avatar
Ivan
I understand. I had concerns and that’s why I left some parts on the case. In the end care or carelessness makes or breaks a project.
Old 02-25-2018, 05:13 PM
Glass beads get into all the oil passages which are hard to clean without removing all the case plugs, the piston squirters, which would have to be removed to be sure there's nothing packed behind them, etc.
206 637 4071
Old 02-25-2018, 07:12 PM
MotoSook's Avatar
I hear you John. The utmost care will be taken before I assemble this.
Old 02-25-2018, 07:49 PM
Chain fence eating turbo
I was going to buy one of these machines at the cost of $15k until I spoke with the vendors that make them.
They had stated that you need to cap off all the oil galleys. Being's that motorcycle engines are small and any oil passage can be easily blocked off, not a problem.
Trying to block off all the passages in a 911 motor seemed to be too much IMO.
Vapor honing does look like fresh aluminum when done (no contest) and does not harm delicate parts, but soda does pretty good too and absolutely 0 worries about harm from baking soda.
Again though, MotoSook, those parts look gorgeous!!!!!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 02-26-2018, 05:59 AM
shbop's Avatar
Those parts look beautiful, but the idea of microscopic glass particulate inside the case is more than I could bear. You're a brave soul. Hubs and brake drums are a whole different animal.
Jon
Old 02-26-2018, 07:19 AM
KTL KTL is offline
Schleprock
KTL's Avatar
You just knocked all the patina off that case and devalued the marque. Haven't you remembered anything from gruppeb back in the day?
Kevin L
'86 Carrera "Larry"
Old 02-26-2018, 08:12 AM
MotoSook's Avatar
Believe me I had my reservations, but I'm not the first to do this to a case.
Kevin - I'll put the patina back, but i'm going to powder coat the inside of the engine!
Old 02-26-2018, 08:48 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Dude, use an oil-shedding coating in there like is used on conrods??? 50 hp awaits you!
BTW I consulted with Elbowmotions on this snake oil vapor blasting treatment and Professor SS Kleine, Phd-PE-CPA-Esq-DDH tells me their non-destructive material testing indicates high potential for catastrophic bling. So you got that going for you, which is nice?
In all seriousness Souk will clean the case inside and out, all plugs pulled, piston squirters replaced, and rinse it 5 times. So he'll be fine.
Kevin L
'86 Carrera "Larry"
Old 02-26-2018, 09:20 AM
MotoSook's Avatar
Ha! I saw Elbow Saturday night and told him I'm going to learn to TIG weld aluminum using his trailer since he's late on the rent. Always good for some laughs that guy.
Exactly the theory on the internal coating. Then I'm only going to wipe down the parts with Slick 50, then not run any oil at all. Imagine the POWAH I'll gain without any oil slushing around.
Old 02-26-2018, 09:26 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Original Slick 50 worked. The internet don't lie. That's all i'm gonna say..............
Kevin L
'86 Carrera "Larry"
Old 02-26-2018, 09:55 AM
Registered Minimalist
75 911s's Avatar
Anyone have any more examples of vapor honing their case?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-09-2018, 09:49 PM
al lkosmal's Avatar
not going to use glass bead on anything that can get inside the engine, period.
+1...
RGruppe #669
http://www.x-faktory.com/
Old 12-10-2018, 08:43 AM
Wildman Emeritus
One downside of retiring is that I have lost access to the blast cabinets that were a short walk into the factory from my office. Had various mediums at my disposal but usually used glass. Lots of Kawi parts done over the years and a lot of stuff for the 911. Most of the 911 stuff, heat shields, tin, mainly external parts, got powdercoated after blasting and turned out very well.
No experience with clearing glass from internals but the shop cleaned numerous aero parts with internal passages after blast without failures. It can be done.
It was a sad day when our ultrasonic cleaner with Trichlor was changed to an aqueous/citric solution. Lots more effort to degrease my stuff.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 12-11-2018, 06:02 AM
3rd_gear_Ted's Avatar
From the land of fruits and nuts:
Ground up ultra fine walnut shells are used to media blast all the surfaces of the California built B-2 bomber to help keep it stealthy clean. It doesn't harm the top secret stealth coating and is environmentally safe too.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 12-11-2018, 09:02 AM
Is the term "vapor honing" an actual process, a company name or a term created to hint that the cleaning process is related to machine honing where a predetermined amount of material is accurately prepped or evenly removed (as in cylinder honing)?
I suspect if a pressurized mix of water and glass bits are shot from a nozzle, it's a cleaning process.
Sherwood
Old 12-14-2018, 05:28 PM
Correct me if I am wrong but isn't "glass" basically silica, which is sand. So the process is using a sand, water, air pressure mix. Does a great job cleaning, but yes, you got to be sure all that glass/silica/sand is out or poof!
Old 12-14-2018, 07:30 PM
Glass beads are used in glass bead blasting. It's an effective, low abrasive media for surface cleaning. Delivery pressure can vary depending on the desired surface finish. It's not sand.
Sand blasting uses silica of varying grit size which is a much more aggressive surface cleaning media.
In both cases, can affect dimensions and thus not recommended for joints or bearing surfaces. Also not recommended if blast residue can't be totally removed.
Sherwood
Old 12-14-2018, 08:49 PM
The 9 Store
Vapor blasting isn't supposed to remove material or change dimensions. I used it on my motorcycle engine and wheels and the sealed bearing bore felt just as tight. It "peens" the metal slightly, so I guess there is some minute changes to the surface so I don't aim it directly at the 911 bearing seats. Proper cleaning is important but that's true for any blasting method.
All used parts sold as is.
Old 12-15-2018, 05:26 AM
Steve F's Avatar
Thumbs up
We had a ultrasonic cleaner with Trichlor back in the days at Hughes Aircraft, loved that thing!!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 12-15-2018, 05:32 AM
