Damaged Porsche 964, advice please?
Maybe I'm in over my head. It has damage as seen and the wiring looks unwrapped (but in ok shape). What's my options? I know how to cut/weld and other mechanicals but this might be a bit much for DIY?
Advise please! Has no engine as well. Subaru it?
Old 03-10-2018, 11:06 PM
Alan L's Avatar
What did you have in mind when you bought it?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-10-2018, 11:30 PM
I would be worried about the body being twisted. That would have to be corrected before any repairs are attempted.
206 637 4071
Old 03-11-2018, 06:16 AM
faverymi's Avatar
Way over my head.
I would need a body shop with a jig straighten machine to be sure new panels go perfect. The buckles on the door pillar jam and rocker look difficult to say the least.
For a motor I'm a purist. But I did like the 964 LS conversion on the interwebs
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 03-11-2018, 06:58 AM
Part it out, find a better start for your project
Old 03-11-2018, 07:13 AM
Sell it to Singer...they own all the other 964's! John in CT
Old 03-11-2018, 07:30 AM
Munky King's Avatar
Way beyond me.
Do you own it yet? If so I personally would part out and then weigh it in.
If you don't own it, I would keep my hands in my pockets and look for something within my personal ability.
Old 03-11-2018, 07:31 AM
Ouch...that is one hard hit. I agree with John Walker...what's your body work and mechanical aptitude / ability? As this car will require someone who is highly skilled.
Old 03-11-2018, 07:32 AM
Registered Minimalist
75 911s's Avatar
A Subie in a 964? just no.
I would partially part it out and do a Singer backdate style car. Keep the parts you'll use and sell the rest of the 964 parts to fund a core 3.6. Hopefully, what you sell the parts for might get you most of the way there.
Once you have a bare tub, it needs to go on a jig and straightened. Then, put on the backdate parts.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-11-2018, 07:56 AM
Yeah, parts car unfortunately.
206 637 4071
Old 03-11-2018, 07:57 AM
If by chance you do not own it yet walk away. My 2 cents.
Old 03-11-2018, 08:34 AM
Alan
To have something fun to look at and tinker with in the garage, where it sits now. Already have got many hours of enjoyment from it.
I appreciate all the advice but I think it's probably out of my skill range as well. I might try to cobble fix the right side, but ultimately I think I should move it on as a whole. Only problem is, if I can't fix it, who else would want it?? If someone has Singers contact number or they're interested, message me.
Old 03-11-2018, 09:12 AM
Under the radar
Trackrash's Avatar
Looks like quite a project. Anything can be fixed. Question is will it be worth the effort and expense. Have you priced 964 motors?
The first thing to do is measure all the suspension points to see if the tub is straight.
Then do an inventory of all the parts you will need to do the repairs.
I could be wrong, but I am guessing that it will cost way more to repair this than a running 964 is worth.
Suby? That would be a real waste of time, IMO.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-11-2018, 09:22 AM
300hp 1800lbs is the goal
pksystems's Avatar
Subaru engine with it's matching transmission reversed and converted to 2wd.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 03-11-2018, 09:24 AM
Singer wouldn’t touch it. For a start each project requires the owner to provide the car. For a second, their requirements are no crash damage.
You need it towed to a body shop to get it straight before you do anything. They will either stretch it back to where it needs to be or inform you it is scrap. Tinkering will get old if there is no possibility of actually returning the car to road or track.
Old 03-11-2018, 09:55 AM
faverymi's Avatar
Post your location.
Maybe someone around you will bite or at least give you a hand
Carrera Luigi CDtdi
Old 03-11-2018, 10:12 AM
Under the radar
Trackrash's Avatar
Sorry, I don't get it. Nothing against Subarus or engine swaps or hot rods. Yea, you can get a Suby engine, etc for a couple of grand. Sure. But by the time you have made all the modifications and fabrications you could have put in a 3.6. (flame suit on)
Let's see, you would have to rewire the car, custom gauges, import all the suby electronics and wire them in. Then the cooling system, custom pipes, custom radiators, custom body work and fabrication to get it all to fit. And I haven't got to the transmission yet.
So if you are really into doing this sort of work and have the skills AND want to work for free for years, go for it. Then when you are all done, it is still a subaru in a Porsche body.
JMO.
Gordon
Old 03-11-2018, 10:14 AM
The sharp one got the motor, the owner got the work.
Bruce
Old 03-11-2018, 10:18 AM
SalParadise's Avatar
Bruce
Bwahahahahhah. Right on to this one.
Old 03-11-2018, 10:28 AM
A good Bodyshop wouldnt touch that
Old 03-11-2018, 10:39 AM
