74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
what plugs are in it
Thanks!Had pressures checked by a Porsche classic shop last year, before I took it home. Don´t remember, but it was ok by them.
-------- 1977 911s |
Bosch WR56 Super 4. Recommended a few places, but can´t really be gaped.
nope!! not those
get the bosch super coppers, nothing fancy. or NGK copper.
TTV is good. I definitely have vacuum at the WUR end. Bypassing TTV does little or nothing on the warm engine. Ordered a set of original spark plugs from Porsche. Fingers crossed.
Hi
I had similar problems with my -75. A local mechanic (with a lot of 911-experience) recommended me to check/replace the injectors. I pulled the injectors and the fuel filter, and found that i had to replace most of it. I tried to clean the injectors, but the problem is that they have to be back-flushed. It can be done, but it's time consuming, and difficult to get a good result. After replacing 4 injectors & filter, the car ran almost perfect. Further down the road i found that the ignition timing was difficult to set because the distributor shaft bushings was worn (impossible to get a stable dwell angle). It's been fixed now, and the next step would be to install a Pertronix ignitor. Injector testing: Buy a syringe at the local drug store. Fill it with cleaning fluid, push it firmly into the injector, and flush the injector into a glass jar You need the injector to open and make a nice spray pattern at low pressure. You WILL feel and see the difference between good/bad injectors. Nice sunday-evening-garage-project. Good luck |
Nope.........
To check out fuel injectors, the easiest war is just run one at a time into a glass jar. Just us a small glass jar and watch it...or get fancy with a baby food jar rig where you can see all at once.
.http://forums.pelicanparts.com/porsche-911-technical-forum/574957-excellent-way-test-injectors-78-911-a.html
He describes that well in post 18.
Chris '75 911s Targa |
76 911S Targa
You do not say what ignition system you have. If you still have points, check the gap (should be 0.012 inch) and the distributor timing. It sounds like your timing might be retarded which will give exhaust backfires as will collapsed points.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
but yes, cold is closed,. hot is open. I was assuming he was testing with every thing operating.
Your assuming correctly
But I´m not having much luck so far. Appart from finding a lot of things that are in good working order ![]() Like I said, I´m waiting for new plugs. I´ll also check out my distributor gaps. Distributor was changed by the PO recently, but I´m not really shure whats in there... Needs to be checked out. Questions will probably follw.
Spark plugs was my main culprit
(New ones are Bosch/Porsche plugs gaped to spec.) I do stil get the occasional backfire, but not bad. Stil mainly low rpm and perhaps more frequent after deceleration. Should I have my mixture adjusted again? Had it adjusted with the bad plugs. Would I be lean or rich? Engine is running slightly cooler than before the new plugs.
A bad or fouled plug can cause the car to backfire/hesitate/ run rough
I’d check the plugs first - even though they are new . Check gaps, coloration, look for debris around the electrode |
![]() Finally got a pic of my distributor. Some suggested adjusting points. Dont think I can with this one. Not a regular, original, distributor. Never seen one like it. Is it an OK one for my car? PO said it was "upgraded"...
No points. Looks like the right rotor...but in the photo (assuming it is not just camera)...looks to be in bad shape (dirty/burned contacts and chipped plastic). ...what does the inside of the cap look like? Is the rotor pushed all the way on? Is there slop in the distributor?
A bit dusty. Looks quite new. But some plastic chips yes. The pin in the yellow circle doesn´t look too good? Maybe a bit rusty. ![]() Inside. Some scratches on the terminals. Otherwise OK?
Looks like some chips in the plastic inside the cap too. Maybe someone turned engine over without getting cap on tight. Both cap and rotor look suspect to me. I would replace (I do when I put on new plugs). If it does not fix...you have a spare for future.
