Factory RSR injection pump and Slide Valve and long block in pieces.
Well the Dick Elverude RSR engine came apart and all is for sale, many of the proven Dick Elverude tricks and development work from back in the day. The engine case is sold as was the crank and rods, but the buyer of the crank has decided to build a much larger lower end with a different crank and rod length so I bought it back.
See the video of it running before it came apart Link https://www.youtube.com/watch?v=lIxZ8Pq4OXk&feature=youtu.be
Here is another link to the thread that has more information along with pics.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/902506-f-s-rsr-flat-fan-slide-valve-engine.html
Bosch ORIGINAL 3.0 RSR Injection pump for slide valve (can be used for high butterfly 25K
Factory original very low time slide valve set up with risers (that are part of the development work) that made gains in HP and pulled harder on the top end. included are factory fuel lines and injectors. 30K
Forged solid factory race rockers and shafts 3,000.00
Mahle 100 mm barrels and J&E 100 mm Pistons with wrist pins- Both were new 6 hrs ago
3.3 perfect oil pump
6 twin plug heads with Ti valves and aase springs. Lots of Port and flow work 3,000.00
Elverude Twin plug dist with cap and rotor and harness 1,500
Elgin billet center oiler cams built to Elverude specs (more development work) 2,000.00
Chain boxes 200.00
Plus what ever else on the lower end you need. Make me an offer!
Thanks, Alain. for technical info and additional pics contact pops directly at jim@torres.com
Old 08-31-2016, 08:43 AM
ttt
Old 11-21-2016, 06:36 PM
ask your dad if he would part with the 100mm cylinders without the J&E Pistons? My 100MM Cosworth would fit just fine.
Thanks,
Bob
Old 11-22-2016, 01:08 AM
100 mm
Hi Bob, sorry for the late response- been in the air. I asked pops and he said he wanted to keep them together. Thanks for checking. Alain
Old 11-22-2016, 03:09 PM
Ok thanks. What does he want for the set of P/C's
Bob
Old 11-22-2016, 03:43 PM
P&C's
Hi Bob,
Pops spoke with Dick today and Dick feels they are for sure worth 2400.00 as they are very low time. Let me know what you think. Alain
Old 11-23-2016, 06:09 PM
100 mm pistons and cylinders
what compression ratio are the pistons and what size are the pins ?rally junky
Old 11-24-2016, 08:06 AM
My Elverude engine is fantastic . Interesting to see more of his work.
1982 911 Targa, 3.0L ROW with Webers
Old 11-24-2016, 09:41 AM
Hi Rally Junky, my notes tell me 12.5 -1 and the pins are 22 mm. Alain
Old 11-24-2016, 11:23 AM
oil & fuel pump
Hello Alain
How much for the 3.3 oil pump and what is your best price on the RSR inj pump?
Thanks George
Old 12-05-2016, 10:04 AM
Hi George, did you get my message? Alain
Old 01-05-2017, 07:37 PM
Yes it will be at the lit show, Alain
Old 02-06-2017, 09:39 AM
Mistake on my part on this pricing info.
Well is was brought to my attention I had mixed up some prices.
The RSR Inj pump was listed at 25K its actually 30K
The slides were listed at 30K, they should have been priced at 25K
Sorry about this. Alain
F/S RSR Flat Fan Slide Valve engine
Bosch ORIGINAL 3.0 RSR Injection pump for slide valve (can be used for high butterfly 25K)[/I] 30K
[/B]
Factory original very low time slide valve set up with risers (that are part of the development work) that made gains in HP and pulled harder on the top end. included are factory fuel lines and injectors. (30K) 25K
Forged solid factory race rockers and shafts 3,000.00 Sold (but have a couple of more sets).
Elverude Twin plug dist only, cap and rotor/harness are not included. 1,500
Elgin billet center oiler cams built to Elverude specs (more development work) 2,000.00 Sold
Chain boxes 200.00 Sold
Old 03-08-2017, 10:08 PM
Bump
Old 04-18-2017, 09:53 PM
