oversized valve guides
Am rebuilding my heads and had to take the guides out. In removing them I discovered that someone before me had drilled out the hole and replaced them with a large valve guide. Now I have removed them which I damage them getting them out and left me with a large guide to replace . Does any of you guys know of someone that can make oversized guides. They are larger than the first oversized guides I see for sale. I can give them the size to make .They are intakes
Thanks |
Try Auto Atlanta. I'm having the same problem with one right now. Also Fat Performance in Orange CA.
I know these guys are on the other side of the country from you but I can highly recommend either Fat Performance or European Motor Works. Fat Performance built my engine (2.2 liter type IV with 147hp) and European Motor Works redid my heads many years later. European Motorworks | Parts for VW Type 4 Engines and other Auto Parts
Elliot Cannon Paso Robles, Ca. "Nationalism is an infantile disease, the measles of mankind". - Albert Einstein Maintain thy airspeed, lest the ground arise and smite thee. |
ASE Master Tech - 35 yrs
long time ago i had a pair of 2.0 heads done by a local shop that "specialized" in Mercedes & VW
- the guy put in Mercedes guides which were larger OD - i was not happy to learn he'd one that could be what you have
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
I found this out many years ago while rebuilding my 2.0 heads. Had a heck of a time finding the correct guides for them. There are actually 2 different guide sizes from the factory, I got the correct ones from EBS Racing 20 years ago. They knew exactly what was going on when I called them.
