Finally Fixed!!!
Some of you may remember my different posts over the past couple years, trying to aleviate a front end shimmy, as well as what I thought was a bump steer issue. I have replaced EVERYTHING over this time (ball joints, struts, tie rod ends, bumpsteer kit...). I even thought I may have had some undiscovered rust somewhere. It was driving me nuts. Thanks to the responses on my last post, I went back and checked the front hub bolts (again). I know about moving the washer with a screw driver to set the tolerance - I thought. I was able to turn that bolt another quarter turn with out creating drag on the rotor and was still able to barely move the washer. I checked both sides. What an UNBELEIVABLE differance. It drives like a new car! To all who responded to my post - tons of thanks!
Scott S |
