Alternator pulley
Does the alternator pulley need to be spin balanced on a >6K engine? Is that a cause for reported belt being thrown? Where is a source for a new alternator pulley?
Thanks, L. McC |
You can buy a new pully from any of the Porsche parts houses, or the used parts people.
Check the back of 9 Magazine for our list of commonly used phone numbers and web sites for Porsche owners. Brian Minson Editor 9, The DIY Porsche Magazine http://www.9magaizne.com |
Re: Alternator pulley
Misalignment of the pulleys is the usual cause for throwing the belt. The stock setup is just fine well over 6000 RPM if nothing is wrong. |
I've never had a problem throwing belts. Most common problem is the belt is adjusted too loosely, causing it to whip around and finally snap-off.
Thank you! John johnechi@hotmail.com |
