Engine Identification
I have just purchased an engine with the following Identification numbers. I think this is an original 914-6. Can someone verify that all of these numbers add up to it being an orginal 6 engine.
Engine *6404153* Type 901/38 Case 901.101.101.3R 901.101.102.2R Cylinder Heads 911.104.306.OR Oil pump 901.105.141.03 Fan shroud 901.106.101.5R Cam Housing 901.105.111.1R 901.105.111.0R
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion Last edited by bcheney; 11-12-2006 at 03:59 PM.. |
These links might help:
http://www.914club.com/specs/engnumbs.php?PHPSESSID=6bcb64174fccb4f2131e55471b3 29d55 http://www.928porsche.net/history914w.htm
We'll be having an ISO9000 audit soon. I've divided our preparation tasks into two groups: Unethical and Unproductive. |
Thanks for the links. The Second is great!
08 Cayenne V6 89 911 Targa Carrera 3.2 75 914-6 Conversion |
engine number
you have in deed the real thing ,, all 914-6 had the 640xxxx number and it should be punched on the flywheels side not the fan,, the case number is also correct as the 0 r and 1R are 911 case#
9140431696 painted, with wheels and brake , with all elctrical working , engine in assembly soon to be driven 011850275 911S soft window targa next in the garage 2000 S4 stage 2 660R stroked |
