Rebuilding a Rebuilt Motor
Hi guys,
I am dealing with my 2L rebuilt motor that I bought last year. I installed in my car once but it did not start. The cranking was slow and ended up seizing up with some metal squeaking noise. One mistake I can think of is I filled the filter with oil prior to the start according to the book "How to Rebuild Your VW Air Cooled Engine" by Tom Wilson(p.149). However I later acknowledged that it's a NO-NO. (914World.com - The fastest growing online 914 community!). It's funny that I could now turn the crank easily with my hand. Anyways I decided to redo it myself. Here are some photos from yesterday. I was first surprised to see how dry they're. There is no oil or lube around the rings and pins. Also, rebuilder did not apply sealer between the case and cylinders mating surfaces. Is that OK? Please feel free to leave your comment. Thanks in advance, BW ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
That motor has had water in it @ some stage,you can see the staining on the pistons and rust on the rings and bores.
Looks like you have no oil circulation within the engine?,why not fill up the oil filter?,that won't cause the issue you have . It is common for the gaskets to be left out but the surfaces must be prepared. The heads don't appear to have been ''lapped ''or for that matter flycut to start with,without this you would have had combustion leakage anyway. Strip the whole motor and rewrite the book on this build,thats the only way you will have a decent engine in the end,you main job is to find why you have no oil pressure............
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. Last edited by porschetub; 02-02-2015 at 05:42 PM.. |
