JRust's Avatar
Switching to Carbs: Distributor ?
I've heard conflicting advice on the distibutor. Do you need to switch from the stock Dist. on a 73' 2.0? Or is there a way to hook up the Vacuum advance to weber 44's? Help
Jamie Rust
73' 2.0
PacificNW914 club member
Old 10-22-2002, 10:46 AM
914 Geek
Some Webers have a fitting on them that sees "ported vacuum". This is a vacuum that occurs when the throttle is open a little bit, but not all the way.
I think most or all Webers have a boss where you can drill and add a fitting for ported vacuum.
This would get connected to the fitting on the distributor dashpot that points away from the distributor body.
If you can hook up the vacuum advance, the stock distributor is the way to go. (1.8 one especially!) If not, then stock or 050 should be OK. Don't bother with the 009, its only virtue is that it's cheap.
--DD
Old 10-22-2002, 11:07 AM
JRust's Avatar
Thanks Dave! You da man. Hey do you have your ride going yet?
Jamie Rust
73' 2.0
Old 10-23-2002, 12:47 PM
914 Geek
Hahahahaha!!!
...Uhhh, that would be a "no"...
--DD
Old 10-23-2002, 01:46 PM
