ss6 ss6 is offline
ss6's Avatar
Funny noise, right rear...
Had to change the brake pads (to Pagid Blue) just before the last DE of the season last fall. Tech inspection noticed a little play in the right rear hub, so they honked down on the axle nut real good which seemed to help.
Now I'm getting a noise from the right rear when I corner (left or right, fast or slow, always the same pitch, but modulates loud/soft based on speed). Local guru sez it's probably just the fresh brake pad resonating on the rotor, but that modulation makes me wonder if something is bent.
Any opinions / similar experiences?
John
Yellow '76 914 3.2
YPAF
Old 01-26-2003, 09:03 AM
bludden's Avatar
After I changed my read brake pads and adjusted them, I needed to readjust them after some driving.
Brian Ludden
Charlotte NC
'76 914
2k2 VW New Beetle Turbo S
Old 01-26-2003, 09:19 AM
Stay away from my Member
campbellcj's Avatar
Wheel bearing...
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 01-26-2003, 09:49 AM
Had an odd noise, Rt. rear also. I thought sure as heck it was a bearing. Turned out the lug bolts had un-torqued themselves enough that the wheel was ratteling on the hub. (Gee, I wonder who didn't torque those bolts tight enough - Duh)
Don
Don Kiepert
'73 Big Bore
'02 GTI 1.8T
Race a Porsche - There's more to life than left turns!
Old 01-27-2003, 07:31 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Jack up the car and wiggle the wheel to see if it has any play. 12 and 6, then 9 and 3 with your hands. There should be almost no play at all. Slowly spin the wheel and listen for noises. Pull the wheel and the brake pads reinstall the wheel and listen again.
Probably a wheel bearing but look carefully.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 01-27-2003, 08:39 AM
