hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
Starting problem Found- Check out this Pic!!!
Wanted to share this with everyone reguarding my starting issues!. I ahve had the hard start from the start. Then got bad the last few days, thought it was the DME Temp sensor, NOT, then possibly the battery NOT, then the starter, NOT, cables NOT! Did a little more digging found that I had a delayed spark at time of ignition. Either the coil or the rotor! Have never had a problem with missing, rough, timing etc with the motor! Poped the cap and you see below! Got a new one at the local parts store, installed, put cap back on fired right up! Had to shut down, my dad said the cap had a vibration, took it off and the rotor wa hitting the cap HARD, got to looking and the gasket was only about 1/4 there! All I can say is I am glad I am learning and that I can work on my own stuff! Just wanted to pass this on everyone I talked to today said the car should not have been running, and it hhad been lik that for a long time! The build up inside of the cap was a BUNCH!
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 01-24-2008, 04:49 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
That has to be the worst I've ever seen. I'm amazed it started at all. Good find.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-24-2008, 06:19 PM
Wanted to add the side shot as well! It had a small piece of the brass on it, I guess that was helping it to light off? Been like that for a long time!
Old 01-24-2008, 06:29 PM
got every las bit of life out of that rotor
1987 944 n/a
Old 01-24-2008, 06:39 PM
Gasket? Tell us why the new rotor was hitting. Old rotor looks like it machined itself to fit when something didn't set up right. Amazing that it still ran.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 01-24-2008, 06:46 PM
sayporsha's Avatar
Crispy!
Jeff
78 911SC, Silver/Black, H4's, Recaros, 964 Cams, Custom Exhaust, 16" 930 Fuchs. Lowered & Loud
Old 01-24-2008, 07:28 PM
Yah, it was a tight fit between the Old rotor and old cap. Goat a new cap coming in today, hopefully that will solve the main problem.
Old 01-25-2008, 04:21 AM
Banned
Good you posted this. Most of the time, people here assume you know basic auto mechanics and things like that are usually cared for on a regular basis.
You're well on your way to THE DARK SIDE. After you know the basics, you start the MODS.
Old 01-25-2008, 08:10 AM
Looks to me as if the car not been serviced in donkeys years
seen them broken ,but never as bad as that
looks like its been on the car since new!
If the rotor arms like that what everything else like? belts/filters etc
Old 01-25-2008, 11:23 AM
THe rotor and cap look to be origional! I replaced the Rotor, Cap and upgraded to an MSD Coil. Bid on some new wires on eBay and lost them at the last min! Everything seams to be doing good so far, just need to get a couple of days driving on it to really tell the dif. I guess I am going to need to start going through all the car! The guy before me had a real "Mechanic" working on it! So I will go through everything. I have a couple more issues, I think just before I got the car there were a few bandaids put on, now they are starting to fall off!
Old 01-27-2008, 08:59 AM
