Fuel related I think?
I have a delema. my car is still being difficult. I have replaced my fuel regulators my wires my fuel filter and the car is still hesitating when I demand power quickly out of it. isn't there a bosch fuel comp that could possibly go bad?? is there any way to reset it. Also that little screw on the throttle body..I have heard that it is a misture and I have heard it is a idle? where should that be.
Old 03-17-2003, 06:52 AM
SoCal Driver's Avatar
Fuel regulators? You mean both of the small round things on the fuel rail?
Could be the flapper in the AFS is sticking or is out of adjustment.
Could be a vacuum leak.
What year and model is your car?
Hint: Add it to your sigiture line.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-17-2003, 07:45 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
When you say "demand power quickly", do you mean WOT (Wide Open Throttle)? Everything Bosch makes can go bad, but they usually don't "reset", you have to rebuy. Could be your TPS is bad/out of adjustment. It should click as soon as you crack the throttle. Hell, it could be you DC, TPS, Lambda, NPT II, EFI, VL, AFS, AAV, or a bad IEHFCHEU valve, ya never know.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 03-18-2003, 02:01 AM
well this is what happens..I start to accelerate with my foot barely on the gas. barelly enouph to keep the revs climbing then it hits three grand and then feels like it is running out of fuel then I step on the gas a little bit more and it shoots off like it should.. I just replaced both fuel regualtors and the 02. is there any way to reset the tps??or adjust should I say?
Old 03-18-2003, 06:21 AM
Ooops!
There is only one fuel regulator. The other is just a hydraulic muffler. If you replaced the dampener with a regulator you've got fuel restrictions!!!
Old 03-18-2003, 02:19 PM
least common denominator
scottmandue's Avatar
EEE II, EEE II, OOOOO!
Sorry
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 03-18-2003, 03:43 PM
Roger Hall's Avatar
When was the last fuel filter change? I like to start with the simple things.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-18-2003, 04:30 PM
I think u are mistaken. I got the part number for the original and te new one and there are two regulators on the feul rail.. that is not my problem.. any others?
Old 03-19-2003, 06:19 AM
ch944's Avatar
If your talking about a 944 you have a fuel pressure regulator and dampner on the fuel rail.
Old 03-19-2003, 10:52 AM
What is the best way to tell which is which? Trying to remember off the top of my head.... isn't there a fuel line that goes into both?
'83 944
Forest Green
Old 03-19-2003, 04:13 PM
Why would you be replacing anything without first diagnosising and confirming a particular part is faulty, or do you just hope installing a nice shiny-new part will fix it???
First check the battery and ALL ground connections, if the fuel pump relay is over 5 yrs old throw it away, check all the service parts; plugs, cap and rotor arm, fuel and air filter and plug wires. Then check the fuel
pressure, air/vacuum leaks and the throttle switch and connectors.
No workshop manual? close the hood until you get one...
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-19-2003, 08:06 PM
well I replaced that little shiny part because I was in mexico and it was spraying fuel out of it.. I took that as a hint it is broken. tell me about the tps. is there any way to free up the butterfly valve??ohh and yes I do have a manual. How do u think I got throught a broken timing belt and replacing the head.?? So please explain..
Old 03-20-2003, 06:16 AM
Why would the butterfly need freeing off? If you can duplicate the problem without driving the car try using another TPS just plugged into the wire harness; rev the engine and twist the TPS at the same time, no running fault = replace TPS.
This way of testing means you don't have to remove the exisiting switch.
Old 03-20-2003, 06:46 PM
todwic's Avatar
"And it's Britwrench off of the top rope...and slam! That's gotta hurt Mean Green Okraland"
"You know it, todwic, I don't think he'll be getting up after that one."
"Ouch! Sand in the eyes? Mean Green, don't you think that was a bit much?"
"Well, todwic, it's no holds barred at the P-car Brawl-a-rama! When he wakes up, that's gonna sting!"
'86 951
Old 03-22-2003, 08:37 AM
I found the Pattern!! right after it rains my car picks up and has no lag or delay. it works perfectly. The air is much more dense. what would control that?
Old 03-26-2003, 11:49 AM
