suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Squeak, Rattle and Vibrate....
I needed to post this. I have an exhaust issue (I think) My car has deveolped an odd squeaking situation after warm up. Sounds like the cat and all the hangers are squeaking. It also feels a little too (swingy) when I grab it and apply any movement to it. Is this a common occurance with this exhaust?..
Frank B
My car is naughty
Old 03-24-2003, 07:00 AM
AFJuvat's Avatar
Your hangars are probably shot.
Not too difficult to replace - soak all the bolts in a penetrating oil the night before you try to remove them - anti-sieze when you put them back on
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-24-2003, 07:08 AM
suck my tail pipe
Frank B's Avatar
should I just re-tighten them?..or have them removed and replaced at a shop?...
My car is naughty
Old 03-24-2003, 07:09 AM
AFJuvat's Avatar
You can do it yourself if you have access to jackstands and some metric sockets.
It is just a matter of unbolting and removing exhaust parts and replacing the rubber shock absorbers.
If your hangars themselves (the metal parts that fit in the rubber parts) are corroded, you may consider taking it to a muffler shop for repair.
AFJuvat
Old 03-24-2003, 07:46 AM
suck my tail pipe
Frank B's Avatar
I may do that any way.. I have Jackstands, but I don't wanna snap a bolt off then have to take it there. THe Rubber Shock absorbers seem to be loose in the hanger, especially in the rear. Most of the noise seems to be coming from the Cat area.. a squeak then a tin vibrating sort of sound. is there something else I should keep an eye peeled for?
My car is naughty
Old 03-24-2003, 07:50 AM
stray15's Avatar
Send a message via AIM to stray15
check to see if the O2 sensor is loose...mine was and i had a metallic sound coming from that area at different speeds...drove me nuts till i figured it out
Old 03-24-2003, 07:55 AM
suck my tail pipe
Frank B's Avatar
I have a strange noise from the front, that sounds like the Fan spinning (on an older car) making contact with something metallic, but it's not the fan.. so I'm stumped as to what that is... I need Motormounts, and my tranny seems to be able to be moved a little bit.. (those mounts are shot also).. so, I'm on a hunt for noises....any suspects?
My car is naughty
Old 03-24-2003, 07:58 AM
AFJuvat's Avatar
Loose heat shield as well (around the CAT)
AFJuvat
Old 03-24-2003, 08:56 AM
suck my tail pipe
Frank B's Avatar
yeah that'd be my guess....anything else?....
My car is naughty
Old 03-24-2003, 09:16 AM
coupe's Avatar
Hi Frank, I have the simular noises after the mechanic worked on my car, he may have had to pull a section of the exhaust and never alighned it properly. The heat shileds are vibrating more than ever on the and around the exhaust manifold.
It is easier to find the if you get the car on a lift and leave it running.
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 03-24-2003, 11:27 AM
suck my tail pipe
Frank B's Avatar
cool, thanks coupe.. how's the ball and chain.. er.. your better half!
My car is naughty
Old 03-24-2003, 12:11 PM
ae1969's Avatar
Send a message via ICQ to ae1969
put her up on 4 stands............
start her up and rev it you should be able to easily spot the problem ...........
and no guessing
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-24-2003, 01:02 PM
suck my tail pipe
Frank B's Avatar
no guessing.. it sounds so serious.....ooh...I'm getting a metallic weird noise from ther front end... could it be Stray's mystery O2 sensor noise?..hmm?hmmm?..
My car is naughty
Old 03-24-2003, 01:10 PM
Roger Hall's Avatar
A large rubber mallet is usefull to find vibrations.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-24-2003, 04:18 PM
stray15's Avatar
another thing i just thought it could be is the finigin pin, good be loose...
Old 03-24-2003, 04:31 PM
paulc's Avatar
check for kittens too
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 03-24-2003, 04:33 PM
stray15's Avatar
and another thing, if i happen to be right for some reason (there is a first time for everything) I have a diagnosis fee of 2 beers
Old 03-24-2003, 04:45 PM
