Instrument cluster with LEDS. "Picture"
I can finally see my instruments at night. What an improvement. I dumped the old mirrored plastic light tunnels and have fitted 9 LEDS, 3 super bright white per section. The intensity of the light is hard to capture on the above picture. The current LEDS aren only working at 50 % capacity.
coupe http://www.p-caronline.com/directory/coupe Porsche 944 Turbo, 1986 Fiat Coupe 20v Turbo, 1997 |
How many miles are on that car?
Nice LED setup
Brad Tompkins Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968 |
Custom User Title
Did you take any pics of how you installed them (pics of the underside of the cluster)?
The car shows 5900 kms, new speedometer. True milage is unknown.
I did not take any pictures. I did this at work and didn't have my camera...Besides it turned out to be a temp instalation. I'm still looking for materials to finally complete the job.
Location: Redmond WA Can anyone help me with my snorkle mod?
Hey coupe, Looks good! Please let us know exactly how you did that, it seems that dim/ dark dashes are a common problem. I know I will have to do something to mine, and that looks like a nice rout to take!
'77 924 - Metallic Blue - enlarged TB/ intake '99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer If it ain't broken, drive it until something is. Have you spent quality time with your Engine Gnome lately? Defend Your Joy |
Looks great.
Please document\photo is possible Looks like a worthwhile upgrade. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
do you recall how much you payed for your speedo/odo setup + installation?
84 944 Non Alcoholic |
At present I'm having electrical faults with the isntrument cluster, so I have to continue fault finding, to make sure that the problems are not related to the modification. Quote:
Ok here are some pictures,
Hello all, I have been having trouble with the electricals in my dashboard since last friday. The wife and I took our 951 for a little fast run, and suddenly I noticed the 'BRAKE PAD INDICATOR'
light on. I wasnt sure of it at the time because the words came up in German. Anyway, I wasn't going to post any pictures, but this afternoon, the alarm came up again and my water temp gauge went up to the red zone, which caused some concern, after all the cooling system has just been overhauled. New pump, thermostat, all hoses, the works. I have noticed a blown diode, in the back of the cluster. Here are some pictures of the LED conversion and the blown diode and track. You must also use a resistor in line to reduce the voltage to the LEDS, reducing the voltage from 13.8 to about 3 Volts DC, failing this, the LEDS WILL BLOW. The resistor I used is an 90 OHMS, 25 WATTS. I used one of the olD dash BULB HOLDERS to power up the LEDS. http://forums.pelicanparts.com/uploads/LEDS+RESISTOR.JPG [/img]
Blown track and diode
Perry951 on Rennlist is building &selling LED gauge lighting packages.
Here is the website: http://home.fuse.net/Porsche951/led.htm
Pete 1989 944S2-Dove Blue Metallic 1985.5 944-Alpine White--sold My P-car Online Profile |
is that $150 for just the instrument panel thingy or for the whole speedo/ odo assembly? id give my first born child for a $150 odomenter
If only I had found the plastic gear sooner, I would have only bought the gear. Maybe that is all that you need, to drive the odometer, assuming that, this is your problem. I happen to have a good old, Speedometer/odometer with a new gear, but it is in Kms and I live in the mIddle East, I would let you have it for US$ 100....
Coupe,
Looks really good and should be simple as well. Could you provide a list of parts you used (part numbers would help) AFJuvat
My plan is still to make an LED holder using perpex plastic glass, the same dimentions as the old light tunnels. Drill 3 holeS 5mm, and fix the LEDS. I tried it, but the plastic perspex glass was 6 mm, so it get cracking, I'm still looking an 8mm thick that may work.
Parts required: 1- 9 x super bright, clear white light LEDS ( Electronic store, like RS, or Farnell. Dont know part numbers 2- 1 x 90 Ohm , 25 Watts Resistor 3- common wire Tools required: Electrical pliers, soldering iron, soldering lead, Multi-meter Method: See drawing, I - LED HOLDER II- RESISTOR III- Lamp holder connect all negative legs of LEDS together (shorter leg of led) connect all positive legs of LEDS together. ( longer leg of led) Do not short between negative line and positive Connect resistor to either one of the wires as shown. The LED is polarity concious, so it will only work one way. Use one of the old light bulb holders to provide you the power supply. Remove old light bulb, and refit back on instrument cluster. I used the middle light bulb holder, the lower connector on the pcp is the Negative. If it doesn't light up, reverse the old light bulb connector.
Yo mama, some one here was selling those gears for your car, at about US$ 10. I cant remember who. Just do a search.
Here is a better drawing
Thank you - I now have an easter break project.
AFJuvat
good idea but it looks like you have a lot of shadowing going on there
1987 924S black on black , does it get any better? |
