Temp gage/ light
My temp gage seems to work as it should but the warning light at the top stays on all the time. Any ideas?
Old 03-08-2021, 02:57 PM
TibetanT's Avatar
timmay:
It would help greatly if you identify the MY of your car for help on this forum. ( let us know, year and make.)
Also, when you say temp gage...do you mean Oil or Water temp gauge?
If oil temp, then it could be as simple as the wires are crossed on the temp sending unit.
If you mean the big RED ! symbol...hmmm, that is not good.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 03-08-2021, 04:48 PM
Sorry- I updated my garage information. 1989 944 base model- 2.7L /5 Speed. The gage i am asking about is the water temp. The gage moves up and down as the car warms and cools.However there is a red "arrow" shape at the top of the gage that stays lit. Thanks for your help
Old 03-08-2021, 05:49 PM
In the Fires of Hell.....
kdjones2000's Avatar
Tim, the NTC sensor has 2 tangs on it - one for the gauge, the other for the light.
Either your connector has fallen off for the light and is grounding out to the block or similar, or your sensor has failed.
This is the non-DME temperature sensor, the one that is not light blue that is used for the DME to compensate fuel mixture...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-08-2021, 07:55 PM
Okay- thanks for the help
Old 03-09-2021, 04:04 PM
