Learjet's Avatar
Running without power steering pump?
Hi
On my 944NA - is it possible to remove the pump or belt on my power steering and still have it work without having to change to a non-servo rack?
Rgds JT
Old 05-29-2003, 02:26 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
I drive my car without using the power-steering pump...
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 05-29-2003, 03:06 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I don't have the turnbuckle for my ps pump, so I've been running sans pump.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 05-29-2003, 04:18 PM
Roger Hall's Avatar
Its possible but the sterring will be much harder than a non P/S setup. Plus added wear on the steering column may cause damage in the long run its not a good idea.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 05-29-2003, 06:26 PM
Go for it, you have nothing to worry about.
Old 05-30-2003, 06:39 AM
Whats wrong with your power steering pump?
Travis
Rennbay, inc. 888-739-7839 x944
Old 05-30-2003, 04:48 PM
Chris_924s's Avatar
Me too- for 4 years or so- no slop in the u-joints
seized pump- bad hose leak.. on day it will get fixed, but I like the "manual" feel.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 05-30-2003, 08:01 PM
944TurboRacer's Avatar
"Manual feel"!?! Without PS assist it is VERY difficult to park the car. The ratios for the manual rack are very different to make up for the increased efforts.
Old 05-31-2003, 12:44 AM
mrmunky's Avatar
i'm running manual steering ATM, i'll fix it when i have time. no biggie.
Fly Yellow 1987 N/A, 5spd, 91k
Old 05-31-2003, 05:22 PM
Learjet's Avatar
Hi
Had a leaking pump, but fixed it with a Porsche repair kit. Still - I am racing with the car and got an input that a non-servo car would give better handling inputs.
Is it enough to remove the belt or can I remove the whole assembely with pump etc? Is there anything I have to block off?
PS You`ll have to exuse any bad spelling etc. Obviously - English is not my native language..!
Rgds JT
Old 06-01-2003, 02:11 PM
The ratio of the manual racks is much easier to handle than a power rack without assist. Power racks running with out fulid have been done by disconnecting the high pressure lines and removing the pump. Most people will fill the rack with a high density lube such as the type used for packing bearings. This keeps the rack in good shape incase you ever want to go back to power assist. If you are tracking and want to use a manual rack I would just go ahead and find a manual rack out of a 924. They bolt right up to our cars and are available from junkyards (ebay). They are still going ot run you around $100. Make sure you get the arms and steering knuckle (u joint) because those parts are not the same on the power racks.
Travis
Old 06-01-2003, 09:23 PM
Burn the fire.
Brando's Avatar
IMO, if you're having trouble steering your 944 without PA, you need some upper body strenght
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-02-2003, 01:52 AM
