ruechaos's Avatar
Where is the oil indicator switch located..?
Hey guys. On my '87 944, I'm having trouble finding the oil indicator switch. As some of you know, my engine is from an '84, and I was wondering if there was such a switch on these pre 85.5 cars that I could use to send a signal to the instrument cluster. As of now to oil warning light just remains lit.
Thanks for the help!
-Tony
'84NA Engine, '87NA Brain/AFM/wiring
harness, all in an '87S Body....AND IT
RUNS!!! kinda...
Old 08-02-2003, 07:16 AM
Under the oil filter
drew1
drew1
wife has 924 turbo
Old 08-02-2003, 08:05 AM
SoCal Driver's Avatar
The later models had an oil level sensor/switch in the side of the oil pan. If the pan was not changed out with the engine swap then there is no level sensor just a wire hanging down -- maybe.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-02-2003, 10:08 AM
TSNAPCRACKLEPOP's Avatar
strap a flashlight to the dipstick.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-03-2003, 04:55 PM
