Has anyone tried a Kuel compressor kit from Griffiths?
If you have, was it difficult to adapt? I haven't decided on a rebuilt or a Kuel kit. Any comments would be appreciated. Thanks. |
i have used the kit from vertex. it was a little troublesome to put on(not too bad) but works great.
951carter,
Thanks for the reply. Is the kit from Vertex a Sanden compressor? I think the Kuel is similar. What was difficult to install? Did you have you splice adaptors for the high/low lines? If so, any tips for installing the new lines? Did the mounting bracket line-up ok? Thanks. |
