Effects of improper wheel offset on 924S
What do you all think the impact of running wheels with the wrong offset will be on my 87 924S?
I purchased a set of 16x7 flat dish wheels with a 928 offset (65mm). With 205/55-16 tires, they fit. However the tires are close to the springs in the front. I've added 1/4" spacers which gives pretty good clearance.
My simple math says I'm still 6.35mm from having correct center line on the wheels. The track is too narrow.
Wheel offset minus stock offset minus spacer width equals track error. Therefore, 65-52.3-6.35=6.35
The car handles nicely, but feels a little "darty" on uneven pavement.
If I purchase 14mm spacers, I'll be off only 1.3mm.
I'd appreciate your advice.
Thanks in advance.
924sBob (the other one)
Old 10-30-2003, 01:26 PM
Non Compos Mentis
Lots of guys run spacers, usually to use late offset wheels on early cars, which is simular to what you're doing.
Old 10-30-2003, 01:29 PM
Let's go shooting.
Dark Skies's Avatar
What's the tyre clearance like on full lock under hard load?
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Clearance under load and at full lock is fine. No rubbing with the 1/4" spacers, even during autocross events.
924sBob ( the other one)
Old 10-30-2003, 01:51 PM
Roger Hall's Avatar
Spacers are fine. Just make sure that you have at least 8 full turns of the lug nut.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 10-30-2003, 07:27 PM
