justin's Avatar
Post swaping DME's
I have a 83' 944 and was wondering if I got a 85.5 DME can I swap them and still be able to chip,if it will even work?
Drive it like you stole it........Justin
Old 11-04-2001, 04:40 PM
951carter's Avatar
Post
the idle stabilizers are different but i believe it will still "work"
Carter
"Rehab is for quitters"
Old 11-04-2001, 06:44 PM
Obin Robinson's Avatar
Talking
Carter
any more info on this? i was interested in going to a newer DME also! i noticed that a few small things would have to be changed, but i was not certain about voltage, resistance, and capacitance levels of various sensors that the DME uses to do its job correctly. is the idle stabilizer something that can be swapped out from a later model for it to work correctly?
thanks!
obin
Old 11-04-2001, 07:33 PM
951carter's Avatar
Post
yes, the idle stabilizer i know can be swapped out.the computer "swap" is speculation as i have not tried it personally but have "heard" of others doing it succesfully.
Old 11-04-2001, 10:20 PM
justin's Avatar
Post
Lets keep this thread going,I want to figure this one out.
Old 11-05-2001, 08:45 AM
EGSMachine's Avatar
Post
they are cheap enough on ebay, if you don't blow it up in trying the swap, you can resell it on ebay.
Old 11-05-2001, 01:06 PM
