Mytoy944's Avatar
my clicker don't stop clicking!
I installed an aftermarket wheel in my 86 and for a while all was fine. Now my signals won't cancel (only the left one) Any ideas what happened?
98 boxster
86 944 n/a by choice still for sale!!!!!!
90 legacy wagon by neccessity ( now dead! thanks Alex!)
02 hyundai by mistake
02 WRX (damn this thins fast!!!) Now it's gone!
2000 Subaru Legacy. (damn this thinns slow!)
92 Corolla (that'll teach ya to total my subaru Alex!) Now dead! (hey kid! ever hear of oil?)
Old 05-24-2004, 08:18 PM
AFJuvat's Avatar
Your turn signal switch is broken.
You need to replace it
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-24-2004, 09:17 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Had the same issue in mine. It was a combination of two things. 1) the turn signal switch auto-shutoff was gummed up, 2) The little shut-off nubs on the back of the wheel are too small.
In my case, I completely dis-assembeled the switch unit, cleaned and re-greased everything, and it works about 75% of the time now (instead of about 2% of the time), but it's still not perfect.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 05-24-2004, 11:42 PM
Burn the fire.
Brando's Avatar
You should be able to take the turn-signal cancel piece off of the old wheel and put it on the new one. If not, you'll be doing it the vintage-volkswagen way
Or master the supreme one-finger-turn-signal.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-25-2004, 12:25 AM
Mine does not cancel after turning left. Pulled air bag off, steering wheel and horn contact wire coil to expose the turn signal switch assembly. Found the little white plastic cancel thingy that was sticking out in the left side of center hole to have rounded corners/edges. This plastic cancel tab must have sharp edges on top and bottom corners to cancel turn signal switch. I took a small flat file and flattened the top and bottom edges so that corners will be squared once again. It works 100% now. fyi.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 05-25-2004, 06:57 PM
I have a complete unit without the headlight washers for sale if you need it.
toddandcharity@peoplepc.com
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 05-25-2004, 07:01 PM
