cdeasy's Avatar
Angry Window Electric Motor Problem
Hi guys,
Big problem here folks. I took the electric motor out last night on the drivers side because it had given up the ghost. Problem now is that the window can move down of its own accord. I tried putting the motor back in but have failed miserably. How does one do this? Is there somebody out there who can help me ASAP?
Thanks.
Colm Deasy,
1987 Porsche 944S with 101K on the Clock!
Old 06-15-2004, 12:07 AM
Burn the fire.
Brando's Avatar
my only guess would be that one of the plastic sliders/rollers wasn't re-assembled properly when you put it back in the door? Those make sure the window has proper support while the motor actuates on the sprocket and window regulator...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-15-2004, 12:26 AM
cdeasy's Avatar
Hi again,
All I have done so far is pulled the motor out of the window mechanism. Everything looked ok mechanically so I tried to put the motor back in but the shaft extending out from the motor body won't go back into the window mechanism. Is there something that I am missing? If I were to guess where the problem was, I would say it is on the last 1/2 inch of travel where the shaft extending out of the motor tries to engage the splines on the window mechanism. What can I do?
Colm Deasy,
Old 06-15-2004, 05:32 AM
SoCal Driver's Avatar
So you left the whole regulator in the door and just took off the motor? Interesting. How did you test the motor?
Most of the time we pull the entire regulator.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-15-2004, 08:21 AM
cdeasy's Avatar
Hi there,
I just took the motor out and powered it up seperately. It didn't turn over at all for me so I then knew it was a dud! The reason I didn't take the whole assembly out is simply down to the fact that (a) I didn't think you needed to, (b) I couldn't find any reference procedure to follow and (c) well, there isn't any c.
L8r dude.
Colm Deasy,
Old 06-15-2004, 08:25 AM
Be specific on the motor tests. You are supposed to put 12 volts across the two pins. If you went from one pin to the motor case nothing will happen. The door switches reverse the 12 volts to run the motors both directions.
Reason I ask is that it is seldom a bad motor that causes window elevation failure. Mostly the switch then the gear teeth on the large regulator gear segment. I would throw the guides and the small plastic rollers in there somewhere.
Old 06-15-2004, 08:48 AM
Stan944's Avatar
As you know, the shaft of the motor is hard to engage completely. I remember I powered it up, and the motor 'pulled itself' in.
My guess is the hole where the end of the motor shaft should sink-in is worn out, and there is no proper mechanical coupling between the warm and the gear (they don't touch). Or the shaft 'went down' underneath its hole. Try to remount it using the method above.
1983 red Porsche 944
Old 06-15-2004, 08:54 AM
Worm gear? You took the motor off of the first stage gear reduction?
Old 06-15-2004, 09:44 AM
Stan944's Avatar
The shaft of the motor ends with a worm gear. I don't know the details of the further gear reduction setup, as I only removed for servicing the motor itself, without removing the complete regulator.
The way I understand it, Colm also removed the motor only, but I might be wrong in my understanding of his message...
Old 06-15-2004, 10:28 AM
I get that impression too as removing the motor with the first stage gear reduction would entail removing the window regulator.
Old 06-15-2004, 02:20 PM
I think what he has done, he has not removed the whole motor assemly. I think he has taking the motor part off and left the gear assembly on the regulator. When he tried to put it back on, the window slipped down and now he can not line the worm gear up with the drive. I think he needs a extra set of hands to pull the window up tight, then try to put it back on. Or , just remove the whole assembly and put it back together. When I part out the cars, I take the motor assembly out first then the regualtor. It is easier for me that way.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 06-15-2004, 07:51 PM
cdeasy's Avatar
Hi guys,
I gather from all your posts that I need to get the whole assembly out and then try and put the whole lot back together again once my new motor arrives.
Thanks for your feedback.
Colm Deasy,
Old 06-16-2004, 12:04 AM
TCMdocs944's Avatar
And....make sure you double test the motor as SoCal suggested.
You could reassemble and have the same problem.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-16-2004, 07:01 AM
Test the motor in the whole assembly.
Old 06-16-2004, 09:46 AM
