early offset spacers value
How much are a set of early offset wheel spacers like these worth?
Also, I bought a set of 964 16" "C2" wheels, but ran into a fit problem on the fronts (16x6). They are a 52mm offset already, but there isn't enough clearance for the hub. So I'm guessing they'd only fit on an early 944 with spacers for late offset wheels, correct? So its kindof a unique set to sell, either back to a 964, or this early->late conversion on a 944 only.
Old 09-13-2004, 09:21 AM
BTW, if you own an early offset 944 and are interested in the wheels, I'd sell them if I can get what I paid. Click one of the thumbs below for the pictures...
They are in -ok- shape. The chrome is flaking off on each wheel, but only in the bottom of the lip, its not painfully visible. Up close, you can see whats going on, but from >5 feet, they look fine.
16x6 front, 16x8 rear.
Rear tires are good, plenty of life left. 245/50 R16 Falken ZIEX ZE512 There was a nail in one when I got them but the seller paid to have it fixed for me. Its holding air fine now. The front tires are thin, would need replaced very soon.
Includes 2 chrome centercaps w/ full color Porsche logo.
I paid $450, so thats all I'm looking for. Shipping would be extra, probably between $125 and $150. Local pickup/delivery is prefered though, so much easier and both of us save money in shipping/paypal fees.
I'm in Detroit, Michigan.
Old 09-13-2004, 09:38 AM
TCMdocs944's Avatar
That is a good deal for the wheels.
The spacers are worth about 20-30 each. Seen great deals in the $30 for two range.
What year is your car? All of the following applies to early offset cars.
To make my boxter wheels fit I used rear spacers and moved my stock rear spacers to the front. They need to either be machined a little or ground down around the inside rim.
BTW.,they will probably fit right up if you just grind down the edges of the hub grease cap. They just won't fill out the wells very nicely.
More info....search "tcmdocs944 + spacers"
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-14-2004, 08:13 AM
Re: early offset spacers value
21mm spacers $20
I run the D90s which are the same specs as the C2s. To put spacers in the front you will have to get the "step" machined to clear the bevel and the hub or the alternate "getto" solution, a combination of grinding the spacers and the grease cap to get them to fit. Call Skip at paragon if you are going to buy new spacers for the front, one of the RennList post said that they sell them already machined. If you are using 205-55-16 tires for the front then 1.75 spacers are the widest you can use, they bring the tire almost flush without any rubbing. This of course will limit running wider tires in the future.
Mark
'86 944NA
Old 09-14-2004, 10:38 AM
TCMdocs944's Avatar
The 3/4 stock early rear spacers fill out the well very nicely.
up to 1.75 would still look really nice
Old 09-14-2004, 11:36 AM
Thanks for the input guys. I have a late offset car, so I can't add any spacers (52mm hubs, 52mm wheels) unless I want to risk greater wheel bearing damage. I'm not in love with these wheels enough to want to go into hub/wheel grinding, especially because I'll be trading up to a 951 in the near future.
Next question, would an early offset car owner be more likely to buy these wheels if they came with spacers or would they probably already have them?
Old 09-14-2004, 12:48 PM
TCMdocs944's Avatar
If it is their first late offset wheelset they would love to have the spacers.
...................maybe
Fitting them does require more work than the simple bolt-on types.
Old 09-14-2004, 01:48 PM
Late off set car !!! This info would have been helpfull at the start of the post.
Just use .25 inch spacers on the front this should give you enough clearance to clear the bevel and enable the C2 wheels to fit. You can pickup Porsche .25 inch spacers on E-Bay pretty cheap as not too many people are interested in them. They are not very thick so they can be easily grounded to fit if required and will NOT require longer studs.
Mark
'86 944NA
Old 09-14-2004, 09:39 PM
Yeah, I didn't realize I left out the late offset part of my car until the end here.
Those spacers I pictured are 21mm. Could I use those with stock studs? I guess I'd be looking for the minimum width spacer that solves my problem, to minimize the amount the wheels are moved from design center.
So how about it, anyone have a pair of .25 or .5 inch spacers lying around that they don't need?
Old 09-15-2004, 05:00 AM
TCMdocs944's Avatar
You can go up to .25 without changing studs.
Many autoparts stores can sell them to you cheap.
I think that you must be able to turn the lugnut 19 complete rotations to be safe... = about 1/4 extra room.
Studs are not that difficult to change though....
Old 09-15-2004, 07:33 AM
Zero10's Avatar
Send a message via ICQ to Zero10
The studs are just pressed in from the back, and are reasonably cheap if you need longer ones. You can probably find the spacers you're looking for on EvilBay for pretty cheap if nobody here has them.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 09-15-2004, 08:22 AM
TCMdocs944's Avatar
The rear studs from an early will also work. Hard to find someone parting them cheap because of the labor but not impossible.
I bought my new ones from pelican...pretty inexpensive for the steel ones.
Old 09-15-2004, 11:48 AM
Ok so I'll summarize.
0-1/4inch (~6mm) spacer = longer studs not necessary.
>1/4inch = need long studs.
I think I need about a 1/2" (or up to 15mm) spacer to do it right.
Anyone have a pair of these they can sell me cheap?
Old 09-15-2004, 02:03 PM
Here is a pricy new 15mm set !
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=42614&item=7921751020&rd=1
here is a new 8mm set !
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=43957&item=7922663077&rd=1
The 8mm set should fit without any grinding. Buy it for $17.98 as it says in the post will end the auction. They are over the .25 inch but you can buy and use the open end steel lug nuts from Pelican Parts. They use these for PCA Club Racing because they are stronger and the PCA tech guys can check how much of the studs the lugnuts are holding on to.
Cheers !!!
Mark
'86 944NA
Old 09-15-2004, 07:11 PM
