Do my tools need air???
I'm near the brink of taking the plunge into air tools. Somehow the entire air-tools has passed my by until now. Seems it will save a few scraped knuckles, and save some time. I'm trying to avoid adding more stuff to an already crowded garage but anyway...
Any compressor recommendations? Seems good config for weekend mechanic work is: 30 gal tank 6hp 8 SCFM @40 6 SCFM @90 also I'll be doing some carpentry with this How do you use air tools, is everything air nowadays? Is it worth it? thanks!
BOB stock 86 944na red/lt.grey 95k (sold) |
I have a Porter Cable compressor, got it at home depot. Same one my brother has had for years with his carpentry job and he swears by it. Might be 8 or 10 gallons, the smallest they make I think, and sounds like all you'll need. It's as big as a beachball, a little bigger maybe, red, and maybe 30 pounds. Mine came with a small brad nailer (for small carpentry jobs like furniture) which I love too. Don't get something too big if you don't need it. I assume it will be fine for your automotive needs as well.
Red 1967 Saab "96", needs help Blue 2002 Pathfinder SE 1991 240SX-SE, auto, trans was shot - junked it |
Air rachet. Use your muscle to break the bolt loose then run it off with the air rachet.
Be very careful with a butterfly 3/8" impact. You can strip bolts with it.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
The 1/2" drive impact wrench has been a lifesaver several times now.
Gene ____________ '86 944 NA '88 Citroën 2CV |
meister member
I have a 5 hp 20 gallon and it works well with my air tools. If you are only running a nail gun you wont need a big compressor or a tank. Thier air usage is low. If you plan on using a 400 ft lb impact then I would go with a larger compressor that can feed it. Size your compressor according to your needs.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
I had a Campbell-Hausfeld that failed within one year of very light use. Bought a Porter Cable "Job Boss" with 150 PSI capability. It has a small tank, 4.5 gallons but relatively large wheels and is very portable. Puts out 6.0 scfm at 90 PSI. Plus, it has a low profile and slips neatly under my workbench. If you require more stored air for high consumption jobs, rig up a secondary storage tank in series with the first, making sure you adjust the output air pressure not to exceed the secondary tank rating, since most are rated at 125 PSI.
Bob S. former owner of a 1984 silver 944 |
Sorry, I have to disagree. Being of the Tim Allen school of power tools, I would say buy the biggest you can afford and can plug into 120V power, unless you have a 220V power in the garage. You can ALWAYS easily cut back the amount of output of air with the regulator but if you're short CFM for jobs like sandblasting, painting, jobs that take large amounts of air for sustained periods, you'll be kicking yourself. I bought a Craftsman 30gal and can do all those tasks without stressing the motor and pump and can still plug into 120vac. YMMV.
It's like money and horsepower; you can never have too much.
Find the largest air consuming tool that you ever plan to use and then add ~5 CFM to it's CFM requrements and get a compressor that can handle that much flow. It might cost a little more in the short run but in the long term it will all be worth it. Any compressor that can handle automotive air tool usage will be able to handle carpentry nailers.
'91 Jeep Cherokee 4.0L HO - Daily driver '83 Callaway 944 2.5L turbo - Soon to be daily driver '83 Porsche 944 NA - sold '78 Porsche 924 NA- RIP '89 Porsche 944 S2 - Parted Looking for a nice 944S for a daily driver. |
Thanks for all your help.
I got the compressor, a 32 gallon 5.5/1.7 hp, 150psi, 8.4/5.1 scfm, 110v, Husky - Campbell/Hausfeld, home depot clearance special for an amazing $230 that included a case with every automotive air tool and accessory I think I will ever need, rachet, impact wrench, paint sprayer, hoses, sockets, inflater, blower, everything. Hitachi 2.5" finish nailer on order for my next capentry projects, framing and roofing nailer next. Excellent addition to garage, yes, I need air, I should have got this stuff 10 years ago.
Don't forget - even air tools require oil. You can either manually oil with a drop of "air tool oil" (not motor oil - air tool oil is lighter weight and has corrosion inhibitors) or use an in-line oiler, but becareful - because if you oil the line (hose), you can't use the hose with your paint sprayer. You'll also need to oil the pin that makes the ratched head ratchet.
Also, if it is a cool or cold day, the air rachet gets uncomfortably cold for use with bare hands. Now, go make some of that neat air rachet noise!
Stay Posted - more to come. |
Very good deal. One of my friends has a Campbell 60 Gallon, and it's so quiet you could stand next to it and talk and barely hear it!
Ryan '84 944 moneysucker edition (SFR, Corbeaus, etc.) '02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's |
Right now at Sears:
http://www.sears.com/sr/javasr/product.do?BV_SessionID=@@@@0708277234.1112044527@ @@@&BV_EngineID=ccekaddefdeijfecehgcemgdffmdflh.0&vertical=TOOL&pid=00916734000 It comes with an 35psi 3/8in air wratchet, 95psi 1/2in impact wrench and an impact hammer. It's kinda loud but doesn't run all the time when using those tools. Now run a DA sander at 90psi 6scfm (Ingersall-Rand 311) and it will never stop running. In order to cut the noise you are going to have to go with an oiled wich is going to be in the $450+ range. IMO this is a nice way to get some tools and a decent compressor for those weekend projects. Michael |
Hope nothing goes wrong with the Campbell Hausfeld. Like I posted earlier, I had one, it failed, I contacted the company TWICE and never received a response.
