Send a message via AIM to hpaulb
mirror problems
Anyone know about power mirrors. The drivers side works OK but noisey. I here ticking at the switch in up or down only. The mirror does nothing. Is there any common problems?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 06-13-2005, 04:31 PM
adrian jaye's Avatar
sounds like the motor is on the way out
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 06-14-2005, 01:55 AM
power mirrors
Anyone have a diagram or any information of the wiring for this. My Hayes manual doesn't help.
98 BMW 740i
Old 06-16-2005, 10:32 AM
roadierfl's Avatar
Hi,
I just did a rebuild on both of my mirrors. It's not a daunting task, at least it wasn't for me. From what I've seen, and feel free to correct me if I'm wrong, but it seems to me that most of the mirror failiors are to do with water getting in the motors and fouling up the contacts.
I used a dremel tool and some wire wool to open mine up and clean the crap out of them and checked the connectors. Didn't seem like it was worth $225 each that I've seen online. I stuck the whole thing back together with marine grade 2 part epoxy.
Could have just worked for me, I don't know if it would be the same for you.
Anyway, hope this helps
1969 Mercedes 280/8 114k miles
[RETIRED]1985.5 944 NA just under 300k miles
[RETIRED]1972 914/6 190k miles
[RETIRED]1997 951 180k miles
Old 06-16-2005, 10:54 AM
SoCal Driver's Avatar
Early design mirrors (most likely the ones in the 924S) are NOT like the later design mirrors. Early ones use a singe motor and a cable capstan that is shifted to drive the mirrors other axis. Later mirrors use two motors and a completely different wiring schematic.
If you look hard enough on Pelican you can find the electrical diagrams for the early 944's. Here is the mirror schematics:
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-16-2005, 08:29 PM
Is that schematic for my year? And how do I take the mirror out to check the motor/contacts? Is the motor in the mirror assembly?
98 BMW 740i
Old 06-18-2005, 02:21 PM
