Writer/Teacher
Getting harder to shift...
As of late, shifting in the 944 has become more difficult. This applies to all gears, but especially 2nd.
Do I just need to change my tranny fluid?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Change it to Swepco synthetic tranny oil -- you should see a notable difference, especially if your tranny's in good shape.
-Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Writer/Teacher
oil swap easy to do? time consuming?
You've never done tranny oil, cjf? I'm shocked!
17mm allen socket, don't overtorque. I think 17 ft lbs.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
Just make sure you undo the bolt on top of the tranny first, to make sure you can add the new oil after you've drained the old one!
-Z.
Writer/Teacher
is this the Swepco 201?
... and how much should I order? Gallon?
A little over 3 quarts, iirc.
edit. just checked, it should take 2 3/4 quarts.
