Back from Beyond
Handling question
Guys, what alignment variables affect "tramlining?" I've done bearings, racks, tie rods, ball joints. The car will follow every little rut in the road and won't run straight and true unless the pavement is perfect. I'd been told that caster affects this "hunting". True? If so, what caster settings should I use?
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-12-2005, 09:48 AM
turbopwr@3000's Avatar
Your front wheels could also be towed out. If your car is towed out then your car would follow any grove in the road. Try towing the wheels in to make the car more drivable on the street.
'87 944 - Daily driver - Hoping to turn it into a 944 RS or CS!
'86 951 - Guru chips, 3.0 BAR FPR, ReliaBoost-1, A/C Delete, 250 lb springs, Cat bypass pipe, more to come...
"Only the people that push the limits find out how far they can really go."
Old 09-12-2005, 10:00 AM
Back from Beyond
Yeah, thought of that and had the toe set to '83 specs. No change. I have got Turbo spec wheels and tires, though. Should I go with turbo spec alignments?
All others GONE!
Old 09-12-2005, 10:15 AM
SoCal Driver's Avatar
Caster and camber. Worn tires. Loose/worn tie rod ends.
Bad a-arm main bushings.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-12-2005, 11:08 AM
Are the "U" joints on the steering shaft worn?My 944s2 wandered and tramlined quite badly until i replaced the shaft.You could actually feel movement in the joints when you grabbed it.Still tramlines a bit but some of that is down to having large tyres (or so i'm told).
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 09-12-2005, 11:09 AM
Back from Beyond
Control arm bushings are good, but I think 944cabby may be on to something. I've got a steering column available to me - maybe I'll swap the steering coupler and see what that does.
Thanks, guys!
All others GONE!
Old 09-12-2005, 11:50 AM
Non Compos Mentis
Wider tires will increase tramlining noticably. Your alignment specs are for narrower tires.
Old 09-12-2005, 01:51 PM
