Back from Beyond
Handling question
Guys, what alignment variables affect "tramlining?" I've done bearings, racks, tie rods, ball joints. The car will follow every little rut in the road and won't run straight and true unless the pavement is perfect. I'd been told that caster affects this "hunting". True? If so, what caster settings should I use?
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Your front wheels could also be towed out. If your car is towed out then your car would follow any grove in the road. Try towing the wheels in to make the car more drivable on the street.
'87 944 - Daily driver - Hoping to turn it into a 944 RS or CS! '86 951 - Guru chips, 3.0 BAR FPR, ReliaBoost-1, A/C Delete, 250 lb springs, Cat bypass pipe, more to come... "Only the people that push the limits find out how far they can really go." |
Back from Beyond
Yeah, thought of that and had the toe set to '83 specs. No change. I have got Turbo spec wheels and tires, though. Should I go with turbo spec alignments?
Caster and camber. Worn tires. Loose/worn tie rod ends.
Bad a-arm main bushings.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Are the "U" joints on the steering shaft worn?My 944s2 wandered and tramlined quite badly until i replaced the shaft.You could actually feel movement in the joints when you grabbed it.Still tramlines a bit but some of that is down to having large tyres (or so i'm told).
1989 guardsred 944s2 cabriolet, 1983 metallic claret 924 lux (sold) |
Back from Beyond
Control arm bushings are good, but I think 944cabby may be on to something. I've got a steering column available to me - maybe I'll swap the steering coupler and see what that does.
Thanks, guys!
Non Compos Mentis
