Let's go shooting.
Rear Fog Light Problem.
My rear fog lights (no front fog lamps) don't work.
Bulbs are fine. Earths look nice and clean. Warning light does not come on. Power is getting to the switch (near console ash tray) when the headlamps are on - just as they should. Power isn't getting to the fuse though - I pulled it and stuck a volmeter across the fuse holding prongs. Is there some kind of relay that may have packed up? No mention of such a relay exists in the owners handbook. I have Porsche factory manuals that speak of a fog relay that exists (models since 1984) but no clue as to where it should be. I can't see it when I look under the dash. Any ideas? My car was bought in November 1983 but might be the next years model. The reason I suspect this is because according to the Haynes Manual all 1983 models had one fusebox with relays all scattered about in various locations. By 1984 there was a Central Electric Board in the left hand footwell with most of the relays attached here with a fusebox (under a flip up clear plastic panel) running beneath it. Also there is an auxillary fusebox just beneath the dash near the side panel (near where my glovebox is - right hand drive). Does anyone have an 1982 - 1983 model? I've heard the fusebox is under the hood. Is that true? Anyway - any ideas where I should be looking to get power across that fuse? Wiring looks OK - nothing looks like it's been disturbed in 20 odd years anyhow.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." Last edited by Dark Skies; 12-31-2005 at 10:58 AM.. |
The Fuse box is in the vehicle. it's under the Steering Wheel. Where the Hood pop handle is on the kick pannel. Look RIght above that and this is what you shoudl see, Well that's the way it is in my 83
http://www.network54.com/Forum/426130/message/1134482918/1984%20944%20Fuse%20and%20Relay%20diagram,%20and%2 0identification%20chart
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
Let's go shooting.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
ahhhhhhhhh i drove my 84 944 from vancouver to seattle after breaking my foot and went to start it the next day and all of the sudden i had no wipers,heater blower,rear defrost. Dont need these in sunny Seattle,grrrrrrrrrrr. Im new here and could use some help as i need to return to Van by thursday for a new cast. Helllllllllllllllllllp lol...thanx and happy new year to all
07 Ranger Super Cabriolet Parting a 85.5 and 2 86 944's ..2 automatics, 1 5 spd 87 944 S 06 Harley Davidson Heritage Softail |
Let's go shooting.
Let's go shooting.
I had the fusebox (auxillary fuses) out to carry out the demister mod (running two 16 Amp fuses in parallel to compensate for the aged defogging grid's extra resistance causing the 25 Amp to overheat). Whilst I was there I checked the rear foglamp fuse / connection. I'm just not getting power to the live side of the fuse holder.
Does anyone know the best place I can run a live wire from to bypass the original (which I can only assume (although unusual) has broken somewhere under the dash?
Let's go shooting.
Come on lads, I know one of you blokes out there can field this. Electrics aren't my strong point - but is it possible to piggyback some live feed from one of the other fuse holders to the feed for my foglamps? Without overloading the wires, obviously. I know that the feed from the demister has a bridge to the fresh air blower, hood release and sunroof.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." Last edited by Dark Skies; 01-05-2006 at 04:02 PM.. |
Let's go shooting.
The sound of crickets chirping is deafening.
Not many here in the states have the rear fog light setup. I know there is the wire for it in the 83. Beyond that I'm lost.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Let's go shooting.
Depends on where you live. Along sea shores and in the mountains. Although mountains realy have low flying clouds -- not really fog. One would think that extra bright tail lights should be coupled to the front fogs.
Also the lenses on the 944's are faceted. Close ups of the euro lights show them to have clear lenses.
Let's go shooting.
It's hard to figure out the flow diagram in my manual - it spans several schematics and, like I said, electrics are not my strong point. I figured the live feed would initially come from the ignition switch down to the fuse direct and then go through a series of relays - given you can only have the fogs on with the lights and therefore require a separate switch. However, last night in the pub, I was bemoaning my woes over a pint with this car nut I know and he thought the relay would be above the fuse - thus making the feed live only when the foglight switch kicked the relay into life and passed current to the fuse.
