Dreaded Leaking Hatch from Hell
My hatch is leaking like crazy. I am having problems with the back end underneith the spoiler. The trouble is, I can't find any holes or reason why it should be leaking! Anyone else have this problem. The leaks are directly beneith the spoiler on the inside corners. Any advice you guys recommend for an easy fix?
1985.5 944NA http://www.kevinswebsite.com/944/ |
Kevin, they may be leaking further up and running down to the corner. Put a garden hose outside and then look to see what's wet. I'm guessing you are going to find the window frame is pulled loose from the window glass where the struts attach to the window frame. This happens a lot in these cars. I started a thread on how to fix that earlier, so do a search for the topic. Hope that's not it and it's something simpler.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Mine was leaking in the same area. New seal and all. I could actually sit in the car and see the water running "UP" and over the seal. magic water.... In reality I guess it was wicking it's way past the seal. I ended up tapping the metal that the hatch seal rides on out a little (it was a little pushed in compared to the other side) and it solved the problem.
Early 85 944 Factory Cold Air Intake Radial Tires |
Let's go shooting.
I had this problem - even after replacing the ratty seal with a new one. My leak was cured by cinching down the hatch a little tighter by screwing the locking pins in a little (equally) more.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
If the drains for the hatch pins are connected, try adjusting the pins to make the hatch seal a little bit tighter (maybe 1 turn in).
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Re: Dreaded Leaking Hatch from Hell
Good luck.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way) 1983 944 Platinum (my daily) 1985/1 Guards Red (project) |
Bite the bullet and do the hatch re-seal. I did it a few weeks ago and it's so dry back there now that my car could double as a Ronco food dehydrator. When I unscrewed (or drilled out screws) the spoiler and side trim, and cleaned out the years of nasty muck that had collected underneath, I saw that the glass-to-frame urethane seal in those rear corners had completely degraded and let water pour right into the car - OVER the rubber body seal. After cleaning out, priming, and re-sealing with 3M windo-weld the problem is solved for the rest of the car's life hopefully. (May it live to see many more timing belts) Plus it's a really nice and clean repair. You can't even tell we did anything to the hatch. I should add that the repair does have its PITA moments, and that it's NOT something that you can do in half an hour over a couple of beers.
http://www.pelicanparts.com/techarticles/944_hatch_glass_repair/944_hatch_glass_repair2.htm http://www.clarks-garage.com/shop-manual/body-17.htm http://forums.rennlist.com/rennforums/showthread.php?t=159567&highlight=hatch
1983 944 Astoria, NY Last edited by foyburgher; 02-28-2006 at 07:08 AM.. |
The real answer:
1) Make sure that you have full glass coverage for your 944. 2) Accidentally drop an anvil on the glass. :-)
Good luck, George Beuselinck |
